Old 02-13-2011, 10:29 PM
Re: Gene's DIY CAI thread
Originally Posted by SVXRide View Post
Harvey,
That would be me. Point to note is that I was running a full ram air system from the front bumper to the stock airbox, with a "Green" filter in the airbox when I took the measurements. New "Scorpion" system is replacing the stock TB to stock airbox system as soon as I can get some welding done (oh, and fingers crossed that the hood still closes without modification )
-Bill
Bumper to airbox:
Scorpion:
Sure Bill, that hood will close....
If you slam it REAL HARD!!!!!
Oh, and thanks for that return phone call.......
Old 02-14-2011, 08:04 AM
Jake@FAPFab's Avatar
Jake@FAPFab Jake@FAPFab is offline
11.24:1 E85
Jake, are you saying that pressure does not equal airflow?
Just asking about your equation.
yes, no JSMath functions on phpbb!
The pressure at the plenum/iris is one thing, but the cfm across the entire system is another.
The stock intake does a poor job FLOWING, but has a relatively low pressure drop across the air filter. I speculate that the "ribs" or stretch section do the most damage.
Old 02-14-2011, 09:07 AM
sicksubie's Avatar
And what hood is this, Bill?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 02-14-2011, 10:41 AM
LetItSnow's Avatar
My 10th Subaru is a WRX
Originally Posted by Bonestock View Post
Get it on a dyno and then we will see. IF there was no restriction or benefit from cleaning up the air flow to the T/B those split intakes wouldn't of made any additional power.... but they did. Posted on this very forum.
Interested... Was there benefit or detriment under 4200RPM? Resonance doesn't discriminate, and MAF technology hasn't changed much. I'd really like to see some dyno action from the other end of the RPM spectrum, which has been proven to suffer from this sort of mod in other applications.
Old 02-14-2011, 11:07 AM
Bonestock's Avatar
Bonestock Bonestock is offline
Nürburgring Warrior!
I'll post up some dyno results this summer when I head over to MASE Engineering. I have no problem swapping parts on a dyno day!
I have to get that 3rd pedal I have been wanting and finally a Hydra ECU before then.
On another note, after my recent mods (see my thread in the general section) and a good dose of seafoam I can finally feel a distinct step in power when I get on it from a standing start.
2010 Subaru WRX
1992 SVX LS-L 89k miles-SOLD!
KTM 250sx MX bike aka "Killer Pumpkin"
Old 02-14-2011, 03:42 PM
oab_au oab_au is offline
Harvey,
-Bill
Nah Bill, you were second on the scene, I was referring to Mychailo's post.
http://www.subaru-svx.net/forum/showthread.php?t=26652
One Arm Bloke.
Tell it like it is!
Old 02-14-2011, 06:42 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Harvey,
You are correct. I actually borrowed Mychailo's instrumentation when I did my instrumented runs.
-Bill
p.s. the hood is a classic glass fiberglass piece. fingers crossed that I won't have to do any cutting, but I have my doubts
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-14-2011, 08:00 PM
Harvey,
-Bill
So what's the story with the "scorpion" intake? Will it do anything the tomyx style intake wouldn't do? Regardless, that looks really badass dude. I could see something like that pulling air from a filter under a hoodscoop. I wonder what that would do in terms of power.
Old 02-14-2011, 09:04 PM
Harvey,
-Bill
p.s. the hood is a Class Glass fiberglass piece. fingers crossed that I won't have to do any cutting, but I have my doubts
Bill, with some solid mounts we could drop your engine 2" for a lower center of gravity AND more hood clearance!
Less angle in the driveshaft as well!
BTW, phone broken?
Old 02-15-2011, 02:34 AM
Myxalplyx's Avatar
Myxalplyx Myxalplyx is offline
XT6 is SVX's Daddy
Send a message via ICQ to Myxalplyx Send a message via AIM to Myxalplyx Send a message via Yahoo to Myxalplyx
/subscribe
Nice DIY intake! Love this stuff! As for the other stuff around what will work and what doesn't......Will just keep reading.
Kevin Thomas
1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph
1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph
1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph
***R.I.P***
2010 RAV4 AWD Sport (13.717 @ 99.19mph )
2015 Honda Fit LX CVT (15.2 @ 90mph)
Old 02-17-2011, 03:09 AM
Banned
... and finally a Hydra ECU....
still waiting for a reply to the pm I sent you...
Old 02-18-2011, 07:57 AM
Bonestock's Avatar
And when I am ready, I'll let you know.
2010 Subaru WRX
Old 07-31-2011, 12:35 PM
92 SVX 92 SVX is offline
OK I finally got around to taking a few more pictures of my CAI
This is what it looks like now
The line going to the valve cover is the breather, I removed the pcv system and replaced it with a breather filter and this line was apparently venting to atmosphere. I started getting fumes in the car
Old 12-06-2011, 02:20 PM
httrdd httrdd is offline
Very nice diy mod! I am going to build this on the LGT!
99 OBP LGT Eg33 swapped.
92 pearl LSL for parts.
Old 07-08-2012, 03:21 AM
steveherman steveherman is offline
Originally Posted by 92 SVX View Post
Ok Here it goes.
First I started by cutting out the Accordion section of the stock tube, for 2 reasons first it allows lots of movement, and second using smooth walled tubing should help air flow.
I cut it as close to the idle control nipple as I could and still put a silicon coupler on you can cut it with a hacksaw. I think I used tin snips. I used a 3" silicon coupler from oreilly's. Part # 8771
$7.99 needs 3 for my setup. I also needed to heat it up just a little to open enough to go on.
Then into that goes a 22 degree bend part #8728
at $11.99. This will connect to a 4" straight piece part #8708 using the clamps that come with all these pieces $8.99
Which then connects to a 45 degree bend
Part #8738 $11.99. Using the second of the silicon couplers this attaches to the stock MAF again needing some heat to fit. Then maf adapter part number #81413 $13.99
Discarding the plastic piece as it is for a smaller diameter piping. You will need to line up the inside and drill new holes to fit your maf.
Then the maf adapter couples to the 90 degree bend part #8698 $10.99
Then that attaches to a 6" straight part #8718 $9.99
Then put your filter on the end. I had a filter so that was not included in the price but if you need one part #8136
cost $24.99
With out the filter it was $91.99 A little higher then my initial estimate.
That is what I did as I pieced them one at a time if you want you can get the short ram part # 8208 for $39.99
comes with one coupler and 2 4" and the 45 bend which means you would only need the 22 bend the 90 and 2 couplers. You do need a straight piece inside the fender but the 4" may be enough I had the 6" so that is what I used.
Using the Short Ram without filter its $78.95
All the pictures are gone.
Kinda makes this thread less helpful.
