intake pressure measurements
I've read quite a bit about home-made ram-air systems, so I've been interested in getting a manometer so I can have a tool to help me design a good ram-air system. So, I finally got around to buying an electronic manometer and taking some intake pressure measurements.
I pulled one of the PCV tubes from the black intake box that attaches to the throttle body and attached a vacuum line to that port. Then I ran the vacuum line through the a/c condensor tube into the cabin. (I pulled the condensor tube from the a/c drain first). ![]() The manometer has a range of +/- 2.2 psi (+/- 150 mBar). The scale reads out in mBar, and 68 mBar = 1 psi. It also automatically records peak pressure and vacuum. Here is a picture of the manometer hooked up and reading the intake pressure at idle. -0.30 mBar = 0.00 psi. ![]() Some of you might remember that I have a very crude ram-air system already in place on my car. All I did was cut a hole in the fender liner just in front of the front left wheel. I decided that the best way to see if the ram-air system was working was to get the car up to 60 mph and then cruise along steadily in 5th gear on flat ground. That way, the engine will be consuming a minimum amount of air, and this gives a chance for pressure to build in the intake track. So, I took the car out for some runs at 60 mph and here are the pressure measurements I got: ram-air hole covered up: -0.01 psi ram-air hole opened up: -0.01 psi So, my ram-air system ain't doing jack diddly for making pressure. I guess I shouldn't be too surprised because the fender liner is anything but air tight. I do think though that having the hole down there allows cooler air to get into the fender well. I also took a few more pressure observations. 1) The pressure never went positive. 2) Strongest vacuum generated was -0.5 psi at WOT 6000 rpm in 2nd gear. -0.5 psi is not too bad at all. Goes to show that the OEM SVX intake system is pretty good. Next phase will be to install a real ram air system like SVXRide has and get some pressure measurements from that.
Real ram air system? What real ram air system???
![]() ![]() -Bill
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX) Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting. Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well. You can tell the lack of craftsmanship by the wrinkles in the duct tape. |
BTW, if anyone is thinking about trying to get some HP from an aftermarket air filter, these pressure measurements tell you the max HP increase that you can get. If you assume the -0.5 psi at WOT 6000 rpm is due to the air filter alone, and you assume that your aftermarket air filter removes all the pressure drop, then the most HP you can expect to gain is around 0.5/14.7*230 = 8 HP. Its more more reasonable to assume that the stock air filter is only responsible for about 1/2 of that pressure drop, so a more reasonable HP increase you could expect from an aftermarket air filter is about 4 HP.
![]() Harvey. ![]()
New Technical Term....
"jack diddly"
![]() ![]() ![]() and yes, it is the OEM JDM CXW S4 SVX ram-air system that I have on my car ![]() ![]() ![]() ![]() -Bill (looking forward to continuing the Mychailo-driven R&D effort on the East Coast!)
thought (maybe already been tried): regarding the ram-air idea... what about attaching a sealed tube to the cutout in the filter lining and using a tube filter?
Moved the manometer tube to a different port on the intake track and recorded -0.7 psi on two 2nd gear WOT to redline runs. If I can eliminate that pressure drop with a ram-air system, then I'm looking at about 0.7/14.7*230 = +10 HP on the road.
Bill, I'll put the manometer in the mail to you today.
![]() -Bill (hoping that manometer-based numbers prove out the "much, much better" comment ![]()
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 06-08-2005 at 12:17 PM. |
Very interesting posts! Any more manometer readings? I would love to read about anyone elses experiences with this device. Read a lot about it in an article called 'Eliminating Negative Boost' in some online magazine. Good stuff! I....Need......more......Info....
I'm going through a host of intake threads and posts throughout the years to get feedback. I like this kind of data.
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
http://www.subaru-svx.net/forum/showthread.php?t=31238 It looks like you've been to that thread though. I was planning to duplicate SVXRide's latest setup, but so far, I'm pretty happy with the simple ram-air system, so I haven't gone as far yet as to cut my bumper. Plus, I haven't been very happy with the ram-air funnel that I bought to mount inside the bumper. I've been trying to find a way to form it, but it hasn't been easy.
![]() So I removed it, cleared the codes and ran faster with the strait 3" tube. I realize later it was WAY too rich, but the funnel did not help me that day.
Cut the bumper? Who said anything about cutting the bumper?
![]() ![]() -Bill
