Old 04-04-2013, 07:26 PM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
Stance GR+ done
Well after getting inspired by a few of the other members here that used the stance coilovers I decided to follow...
The lack of communication and updates with amr suspension had me a little gun shy and the money i save with the sti suspension will help offset the cost and give me an excuse to buy a few new tools.
I also bought the 05/07 suspension with 7k/5k spring rates $1080 shipped
I just searched and I need to thank SMC and crazypilot for taking the time to post their swaps !!!
[SIGPIC][/SIGPIC]
Old 04-04-2013, 07:30 PM
jman050's Avatar
Its a Classic!
Re: Stance GR+ done
I lowered the front around between .75 and 1 inch which gives me a stance I am fairly happy with and the control arms are still even. The strut body bracket needs to be widened to atleast 28mm to fit the svx not a hair less....or dont even think about it.
[SIGPIC][/SIGPIC]
Old 04-04-2013, 07:36 PM
jman050's Avatar
Its a Classic!
Re: Stance GR+ done
I also used QS components for my endlink making. I ordered enough for my to do my rears as well so now im just waiting on dayle and the machine shop to send out the rear sway bar I ordered.
Overall I am very happy with the performance. I am completely stable at stupid fast speeds that I havent seen in forever. I know i may be lectured but I just had to test it. And with the hankook evo v12 tires the overall handling is excellent I just need to stop procrastinating the rear diff bushings.
[SIGPIC][/SIGPIC]
Old 04-04-2013, 08:20 PM
92 SVX 92 SVX is offline
Re: Stance GR+ done
Looks very good. And it works well for you that is the important thing.
Old 04-04-2013, 08:37 PM
Re: Stance GR+ done
Awesome, looks great. Very clean. And just the right height too. About the same height as I have mine at in fact.
Did you machine the top plates yourself and put the studs in?
Old 04-04-2013, 11:07 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Re: Stance GR+ done
Very nice.
Where did you get Stance Coilovers for $1080?!?!
Also, what did you do about mounting the front sway bar?
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 04-05-2013, 12:22 AM
smc smc is offline
Re: Stance GR+ done
Glad your happy with your new suspension
Old 04-05-2013, 01:29 AM
bishop bishop is offline
Re: Stance GR+ done
I like it a lot, this looks like machine work i could handle, though wouldnt sti spring rates be a bit soft on our heavier cars?
edit: nvm, saw that they were custom ordered.
Old 04-05-2013, 05:47 AM
Re: Stance GR+ done
Looks great! I still love my Stance coilovers, the car feel glued to the road. How many hours was the install? Using the 05-07 STi was smart, the lower mount is already much closer to fitting than my 02-07 WRX. I believe Stance sells the tube portion of the lower mount as a fabrication part. If/when I redo mine in the future I'll buy those and add my own flanges to perfectly match the SVX knuckles.
Edit: Yep, here. But at $229/pair! That's a little outrageous if you ask me.
See his last picture, looks like he used a beefier version of what I did.
Old 04-05-2013, 10:34 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Re: Stance GR+ done
Have you just done the front?
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-06-2013, 02:36 PM
jman050's Avatar
Its a Classic!
Re: Stance GR+ done
Very nice.
EBay Texas motorsports store I believe the sellers name is txautoplex
[SIGPIC][/SIGPIC]
Old 04-06-2013, 02:37 PM
jman050's Avatar
Its a Classic!
Re: Stance GR+ done
Bill
No I did the rear. The picture with the drill press is the rear mount with the new stud hole.
[SIGPIC][/SIGPIC]
Old 04-06-2013, 02:41 PM
jman050's Avatar
Its a Classic!
Re: Stance GR+ done
Yea I did all the work myself probably took me 15hours total but I was building the end links at the same time. There was at least 8 hours of grinding and measuring but I was being very careful
[SIGPIC][/SIGPIC]
Old 04-08-2013, 10:46 AM
jman050's Avatar
Its a Classic!
Re: Stance GR+ done
Does anyone know if the sti brake lines are compatible. I really don't like the how the svx lines are mounted
[SIGPIC][/SIGPIC]
Old 04-08-2013, 11:09 AM
Re: Stance GR+ done
What's the difference between how they're mounted in the STI versus the SVX?
Most likely the fitting sizes are the same at both ends of the lines, but the lengths may not work out right.
