Old 03-29-2013, 09:39 AM
motorsport drop springs
I had the springs powdercoated and now dont know which ones are front vs rear. One pair is noticeably taller in height...
Any way to distinguish? Thanks
Old 03-29-2013, 10:01 AM
Re: motorsport drop springs
I believe the taller ones are the rears. They should also be easier to compress.
Old 03-29-2013, 10:06 AM
You'll know as soon as you remove the stock ones.
Old 03-29-2013, 02:40 PM
I've removed the rears so I can compare...but since these are lowering springs I am not comparing apples to apples correct?
Old 03-29-2013, 02:55 PM
That's correct.
Old 03-29-2013, 07:06 PM
To follow up, as icing stated earlier...the taller springs are in fact the rear springs
Old 03-30-2013, 10:07 PM
And the front wire is thicker than the rear.
Old 04-05-2013, 12:31 AM
Green1995SVX's Avatar
Great call with regard to having them powdercoated. The stock finish on them is awful. Mine are covered with rust, and I don't even drive my car in the winter. I love the ride comfort, and the ride height though. They're an excellent option!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-05-2013, 07:08 AM
That's certainly reassuring Mike, thanks! I'll keep you all posted once they are installed. Im overhauling the entire suspension, replacing everything with new OEM parts. Just got all rear suspension components powdercoated...down to the rear sway bar brackets!
