Not sure where to start...transmission is giving me problems
I am not sure if this is the right place to post my 92 SVX transmission is going out no third gear right now.I have talked to 2 transmissions shops here in San Diego and both quoted me 4500+ for a rebuilt transmission. I really think I just need to get rid of the car.....any thoughts or ideas?
Re: Not sure where to start...transmission is giving me problems
Go with a 4.44 swap. Can source the parts for a lot cheaper and will be an upgrade in almost all aspects. Quicker acceleration, better gas mileage in hilly areas and city driving. Better reliability, even when compared to typical transmission shop rebuilds unless it's a Subaru Reman trans. And much cheaper than almost all other options.
It is a no brainier. Check with these guys on here on what you need to shop for. Your transition shop can do the work of the install
When I was in school I sucked in sports. Then I found out I can buy trophies and now I am great at everything. |
If you want help here, you need to let us know where in the U.S you are.
1995 POLO LSI 76K MILES SOLD Last edited by SVX92-97; 02-26-2013 at 06:36 PM. Reason: edit |
San Diego I'm guessing
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
I am in San Diego CA....
Im in the same boat. I don't plan on taking it to the shop tho. Im thinking about just replacing the high clutch and then start shopping for 4.44 stuff for later. I probably should just go straight to the 4.44 however and not mess around with the high clutch.
My car is still a daily driver. I just keep it in second. Need to get it fixed before something else goes due to the extra stresses.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black 92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho ![]() |
With so much love for the 4.44.. isn't there a disadvantage of higher cruising RPM?
My car is currently in ill shape and in need of service and still cruises in 60 mph under 2000 RPM.
I got my girl, I got my glass, I got my car and I'm ready to f... |
![]() Dont give up the car, then all the vw dueds will take the engine ![]()
Alexander (Norway) My subarus: 1992 Svx LSI 5-MT(3.54) 1998 Legacy BG 2.5L GX |
Not a bad trade off for 100 or 200 RPM. It will not down shift as much, gets better MPG in the city and back roads. And the biggest + is reliability and expense of fixing the car better than it was. Maybe 1 MPG.
Not really. You might lose a tiny bit of high speed (I'd guess like 80+ mph) gas mileage, but many people have reported that they gained city mpg enough to make up for it. The better reliability would make any slight disadvantage meaningless by comparison anyway.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
I think I preferred the way that the stock transmission drove over all, but I always felt like I could not trust it. When it inevitably failed, I had the 4.44 installed specifically to get the increased strength and reliability.
I also like the fact that if the 4.44 does fail, I can easily find a replacement in most any junk yard. Not so with the Stock SVX tranny.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 Last edited by Sean486; 02-27-2013 at 05:56 PM. |
I am not convinced with all these accolades for the 4.44 transmission. It is still a used transmission, requires rear diff modification and, what will the availability of a good low mileage one be as the years go by. I would rather consider an original rebuild with longassnames's valve body and TCU, and maybe other Level 10 components. I don't know if it is BS but, when I had mine rebuilt 35K miles ago, the shop said the Subaru replacement clutch discs were a heavier duty upgrade from the 1992 originals.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
With the rate that transmissions fail (I've now encountered 2) someone should definitely set up a shop that tackles this problem head on directly and making it easy as pie for the end user (any SVX owner) that is inexperienced as myself when it comes to such instances as the transmission. (Yes, a dedicated side business / website for affordable SVX transmission replacements) I'm a business person but I know jack about everything requiring to source such a kit and whatnot. I wish I could offer such an affordable option/service for anyone looking for a replacement... but someone should anyway.
1994 subaru svx le 112k |
