Hey all,
I slid on some snow-covered ice in a turn and hit a curb, which bent my rear lateral link on my driver's side. ![]() ![]() I searched and searched the forums, but came up with null for stock lateral links. I bought a 92 Legacy one from the pull and pay and put it on, but it's too short so the tire is toed out about 5 degrees and drags. I have been planning on getting STI adjustables soon, but right now I'm short on money and I need to find a quick fix ASAP as I'm currently borrowing my friend's banged up off-roading Wrangler. Are there any other Subaru links that are the right length for the SVX? PS: Preferably from an Outback, Legacy, or Impreza, as my local junkyard has no WRXs/STIs or any subaru newer than 98. Thanks.
1992 Dark Teal LS-L w/ 165k+ miles (traded ![]() Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs ![]() 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) Last edited by EdWindows; 12-09-2012 at 08:12 PM. |
Re: Stock Rear Lateral Links from other Subarus
I just replaced my rears.
Icingdeath did u throw those old ones away? |
Rear lateral link
20255PA000....Lateral Link Ay R....$95.00 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 12-09-2012 at 08:59 PM. |
If it's going to be very short term. You can use two legacy links, the toe should even out. Your camber will suck, but it should drive better than 5* of toe.
Yeah, I was thinking about doing that. I was just wondering if there was any other link that was longer.
1992 Dark Teal LS-L w/ 165k+ miles (traded ![]() Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs ![]() 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
WRX sedan lateral links are longer than those found on older Impreza/Legacy/Forester models (same length as the 2004-2007 STis). Might work. WRX wagon ones are as short as the older Impreza/Legacy/Forester models so skip those.
edit: The SVX lat links are 16" bolt center to bolt center. The megan adjustable sti ones I've got are about 15-17", and are for a GDF Impreza (05 sti sedan). Professor Google says that the 90s-05 or 06 imprezas are all also 16", so any of those should work.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() Last edited by icingdeath88; 12-10-2012 at 07:32 PM. |
![]() I shall go and pull various links at the junkyard and measure them to make sure they will fit.
Well I went back to the junkyard and pulled a few lateral links off of various Subarus.
I found that most of them were 15 3/4" from the center of each bolt hole, so I just grabbed the other legacy link and put that one on. Nicely enough, since all my struts are weak, my car sags enough to where all my wheels have about 1 degree negative camber, so the legacy links only caused about half a degree of positive camber.
