Old 12-09-2012, 09:33 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: Stock Rear Lateral Links from other Subarus
If it's going to be very short term. You can use two legacy links, the toe should even out. Your camber will suck, but it should drive better than 5* of toe.
Old 12-09-2012, 10:04 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Yeah, I was thinking about doing that. I was just wondering if there was any other link that was longer.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 12-10-2012, 07:04 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
WRX sedan lateral links are longer than those found on older Impreza/Legacy/Forester models (same length as the 2004-2007 STis). Might work. WRX wagon ones are as short as the older Impreza/Legacy/Forester models so skip those.
Old 12-10-2012, 07:25 PM
I measured the SVX ones once... lemme look and see if I can find it.
edit: The SVX lat links are 16" bolt center to bolt center. The megan adjustable sti ones I've got are about 15-17", and are for a GDF Impreza (05 sti sedan). Professor Google says that the 90s-05 or 06 imprezas are all also 16", so any of those should work.
Old 12-10-2012, 10:30 PM
EdWindows's Avatar
Awesome, thanks icing!!!
I shall go and pull various links at the junkyard and measure them to make sure they will fit.
Old 12-12-2012, 11:34 PM
EdWindows's Avatar
Well I went back to the junkyard and pulled a few lateral links off of various Subarus.
I found that most of them were 15 3/4" from the center of each bolt hole, so I just grabbed the other legacy link and put that one on.
Nicely enough, since all my struts are weak, my car sags enough to where all my wheels have about 1 degree negative camber, so the legacy links only caused about half a degree of positive camber.
