Old 04-10-2012, 01:45 PM
Red94Svx Red94Svx is offline
Stock intake vs. Cold Air and hood scoop
I was thinking of improving air flow to my car and I was wondering the pros and cons of each and what would give the most horsepower?
Few thoughts I had
How much of a difference would I see from the scoop vs. Cold Air cone?
Best option for gas mileage?
Old 04-10-2012, 02:38 PM
Re: Stock intake vs. Cold Air and hood scoop
Your best option for horsepower and mileage is stock. The factory set-up flows very well and sucks in cold air from the inner fender area. A cone filter will suck in hot air from the engine bay. A scoop would make little or no difference and introduces the possibility of sucking in water with possible catastrophic consequences.
Old 04-10-2012, 03:06 PM
The only intake with proven gains has been the dual-track one that YT and Myxalplyx put together, but that was with a set of aftermarket cams, not a stock engine. The parts of the stock intake that flow poorly are the accordian style pipe and the funky airbox that feeds the throttle body. Smoothing those features out is where you may see gains, not with changes to the filter.
It's been established that the "ram air" intakes are next to useless. Off the line you have no airflow to give you "boost", and at high speed you won't feel the difference that a half PSI or so will give you.
Old 04-10-2012, 03:14 PM
Having added a full ram air system to my first SVX back in 2001,
before I evan drove her home
and having drag raced with and without ram air on the same SVX the same day,
I have to agree with Blacky and Chris.
Old 04-10-2012, 03:28 PM
I've seen some people put the cone in the fender would I see any increase with that setup?
Old 04-10-2012, 03:51 PM
You'd see an increase in how much water and road debris your engine injests, but otherwise not much. Realistically without significant mods you won't get any measurable improvement in performance. Generally the "cold air intake"/cone filter setup gives people the impression their car is faster because it makes more noise.
Old 04-10-2012, 04:19 PM
How about the K&N or some other low restriction filter?
Old 04-10-2012, 05:18 PM
92 SVX 92 SVX is offline
If done right the filter in the fenderwell does NOT increase water or debris it does however give you cooler air then whats available in the engine bay, and if you have replaced the "accordion" tube with straight walled tube better air flow will result.
Does cooler air help? yes but perhaps not enough to justify it.
Old 04-10-2012, 05:21 PM
Our intake system is one place that the SVX really shines!
If you change it for a more agressive sound, or a sportier sound,
or to look cool, or just because you can, then GREAT!
Its YOUR car!
Make it your own!
not a stock one in the bunch.
Old 04-10-2012, 05:43 PM
This is what Mine has been changed to look like, is it just for looks, perhaps I like it better though.
Old 04-10-2012, 05:55 PM
LetItSnow's Avatar
My 10th Subaru is a WRX
Weight reduction. Tape over the gaps between body panels. More weight reduction.
For fuel economy, flow is really the least of your worries - at least through the engine.
Old 04-10-2012, 06:03 PM
thickasxthieves thickasxthieves is offline
Send a message via AIM to thickasxthieves
92SVX I really like what you did with the intake manifold. Is that painted/powdercoated or something else fancy?
Maybe someday I'll be able to provide insight into stock intake vs 'cold air'....someday...maybe...
until such a time.. sti panel filter in place of stock filter may be good for a smidge more airflow.
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver
Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs
parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set
Old 04-10-2012, 09:47 PM
its ceramic paint, I thought about powder coating but the extra money was just not in the budget.
Old 04-11-2012, 01:50 AM
So after the maf does the cone sit there or in the fender?
Old 04-11-2012, 02:36 AM
Few thoughts I had
What are your goals, really?
