Show Off Your Wheels !
Post Pictures of your Rims & Tires!
please add Spec Info of both rims & Tires |
Re: Show Off Your Wheels !
You might like these threads:
Wheels that fit the SVX: http://www.subaru-svx.net/forum/showthread.php?t=29638 Wheels that fit the how to .pdf http://www.subaru-svx.net/forum/showthread.php?t=56613 |
Wheels are 18" Focal F5 rims with 225 45 18
[IMG] ![]() |
Privat - Netz Gloss Black w/ Mirror Machine Lip
Size: 18" x 7.5", Offset: +45, Centerbore: 73.1mm Tires: HANKOOK Ventus V12 Evo K110 225/40R18 92Y ![]() ![]() |
Awesome !
i like both those rims Conn your svx's rims look like they say FAST! Quote:
s have, the tires they decided to go with and specs are great info ! Last edited by SubaruJawn; 11-18-2011 at 06:22 AM. |
Mazda RX8 Wheels
18"x8" Running with 225/40/18 Continental ContiSport Contact 2 Tires Subaru Outback Center Caps ![]() ![]()
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
heres mine ,
lexus is300 i think they were from ? 16" only a couple of mms difference in offset and my custom nail polish painted crappy ebay subaru centre cap stickers ![]() https://www.facebook.com/media/set/?...1&l=bd5634b690 |
sooo no one else is running different rims ?
k'mon svxr's show your wheels |
My previous SVX had Enkei Shoguns. 17x7.
2005 Mustang GT wheels 17x8.
I'm also running hubcentric rings. I can get info on my tires later if anyone is seriously interested, but they are all-season Sumitomos.
Trevor Avondale, AZ 1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13 1992 LS-L Claret 178k totaled 10/26/09 ![]() 1987 BMW 325is 60% of the time it works, every time |
i would love these rims on my SVX ![]() Last edited by SubaruJawn; 11-24-2011 at 05:52 PM. |
More than likely those are staggered, so they will not work, unless you feel like burning up a transmission.
Staggered = different wheel sizing front and rear, and typically different sized tires to go with them. Different size tires are bad juju for AWD vehicles, since your front and rear wheels will be rotating at different speeds. It will lead to overheating and failure of your center diff.
***Disclaimer: If you try the following I am in no way responsible for the results.*** If you're VERY careful about the tire sizing it should be possible to run a staggered setup. For example, 245/40/18 and 275/35/18 are within a tenth of an inch in diameter depending on the manufacturer. Realistically speaking, people run their tires farther out of sync than that simply by having their air pressures off.
why not make sure they are all the same rims ? get all 4 rears and put them on front as well or all 4 front ? i'd rather go with all 4 rear, LOVE THE DEEP DISH ! |
