Old 11-24-2011, 05:47 PM
SubaruJawn's Avatar
SubaruJawn SubaruJawn is offline
got my SVX 12-8-11
Re: Show Off Your Wheels !
Originally Posted by tiv0 View Post
2005 Mustang GT wheels 17x8.
I'm also running hubcentric rings.
I can get info on my tires later if anyone is seriously interested, but they are all-season Sumitomos.
hmm 05 mustang.... doesnt the older mustangs have same bolt pattern ?
i would love these rims on my SVX
Old 11-24-2011, 06:15 PM
More than likely those are staggered, so they will not work, unless you feel like burning up a transmission.
Old 11-24-2011, 06:21 PM
SubaruJawn's Avatar
got my SVX 12-8-11
staggered ? burn up transmission ? i dont understand
Old 11-24-2011, 06:40 PM
Staggered = different wheel sizing front and rear, and typically different sized tires to go with them. Different size tires are bad juju for AWD vehicles, since your front and rear wheels will be rotating at different speeds. It will lead to overheating and failure of your center diff.
***Disclaimer: If you try the following I am in no way responsible for the results.***
If you're VERY careful about the tire sizing it should be possible to run a staggered setup. For example, 245/40/18 and 275/35/18 are within a tenth of an inch in diameter depending on the manufacturer. Realistically speaking, people run their tires farther out of sync than that simply by having their air pressures off.
Old 11-24-2011, 07:02 PM
SubaruJawn's Avatar
got my SVX 12-8-11
ah ok
why not make sure they are all the same rims ?
get all 4 rears and put them on front as well or all 4 front ?
i'd rather go with all 4 rear, LOVE THE DEEP DISH !
Old 11-24-2011, 08:15 PM
processengr's Avatar
Running the Tribecca wheels, with their 55mm offset will allow 255-35-18 tires.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 11-24-2011, 11:50 PM
smc smc is offline
18x8 wheels from an 2008 STI fit Beautiful. Tires are 245/40r18. Zero clearance issues.
Im SOoooo happy with how these turned out.
Old 11-25-2011, 12:20 AM
flamestone's Avatar
flamestone flamestone is offline
I'll see your early model Tribeca wheels, and raise you a set of late model Tribeca wheels.
