Old 02-22-2011, 02:06 PM
Cam Cam is offline
Ignition Mechanism
So, I was redoing the ground to my deck, and while I had the deck laying out by the shifter I was experimenting with different ground locations for the deck, attempting to clean up some alternator whine/ground loop issues.
I was sitting there, turning the car on/off to relocate the ground, taking the keys out each time. Then, all of a sudden, the keys would still come out, but the ignition switch would not come back to the "LOCK" position.
So, I am having to take the ground off the battery to turn my car off.
Is there something electrical back behind the stereo that would cause that? Or do I need to source a new ignition switch?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 02-22-2011, 02:20 PM
Re: Ignition Mechanism
Where all did you try grounding the head unit?
Old 02-22-2011, 02:27 PM
Cam Cam is offline
To the battery, to the ground on the block, random points on the chassis/frame...it just didn't help. No fuses blew or anything. They were all good grounds. The problem may be internal to my amplifier. I am hoping not. I did a kind of ghetto job on the stereo install 2 years ago...so I am going to fix that and see if it helps. Electrical tape will be replaced with proper connectors and heat shrink.
Cam
'92 Ls-L Dark Teal
Old 02-22-2011, 02:58 PM
it's possible you messed up the wiring from the trans to the ignition switch. if it doesn't think your car is in park it won't let you turn it to lock and take the key out, but should still let you turn it off.
Old 02-22-2011, 03:43 PM
dragoontwo dragoontwo is offline
Did you try making sure that the shifter went ALL the way forward? I've had it happen to me a couple of times.
'92 SVX LS Pearl White - 6mt
Old 02-22-2011, 04:11 PM
Cam Cam is offline
Well, my lock cylinder is worn out. Everything else is working perfectly. I am getting shavings out of the cylinder when I remove the keys. Car starts in park and neutral. But the key still won't rotate back into the lock position. Ordered a new lock cylinder. 32 bucks from my contact.
Cam
'92 Ls-L Dark Teal
Old 02-22-2011, 06:27 PM
Are you going to have it re-keyed for your keys?
Old 02-22-2011, 06:48 PM
Cam Cam is offline
The dealer cant match a lock cylinder to your current vehicle. You have to get a completely new lock set for the entire car. Or so I was told.
I may do it in the future, by right now I am gonna rock 2 different keys. No biggie.
Cam
'92 Ls-L Dark Teal
Old 02-22-2011, 08:27 PM
Nah, two keys sucks worse than you'd think. It's manageable if they're different styles though.
Old 02-22-2011, 09:04 PM
Cam Cam is offline
I had two keys on my accord. It wasn't too bad. I have more important things to fix on the car right now.
Cam
'92 Ls-L Dark Teal
Old 02-22-2011, 11:02 PM
You and me both man. So how's the 11:1 life?
Old 02-23-2011, 12:44 AM
Cam Cam is offline
Excellent . I got the idle evened out a little bit, it doesn't die anymore, but its still a little rough around 600 RPM. I feel like I need to adjust timing and AFR...but I cannot do that until I replace the computer.
Since I got the idle figured out, I will most likely wait until the tranny has gotten some love before I dump more money/power into the engine.
I will, however, post pics in my engine build thread about how I adjusted the idle and which screw it was, etc...
Still planning on the overhaul?
Cam
'92 Ls-L Dark Teal
Old 02-23-2011, 12:46 AM
Cam Cam is offline
If that is it, what wires back there belong to the ignition? I have had my hands much deeper behind the stereo than I did today, I don't feel like I could have messed anything up.
Cam
'92 Ls-L Dark Teal
Old 02-23-2011, 10:56 AM
pile o' wrx's Avatar
pile o' wrx pile o' wrx is offline
My RS did this a few weeks back.
I pulled the covers for the steering column and found the cable for the trans, and tumbler pawl, had bound up locking the key in place. just a quick nudge with a small, chisel-head, screwdriver and everything is reseated. She's mostly highway miles so I don't have the wear in my tumbler that you describe.
John
'05 STI
'00 2.5RS
Old 02-23-2011, 12:07 PM
kinz kinz is offline
Sounds like time for a remote start.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black
92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white.
