Old 09-01-2010, 04:17 PM
moepower moepower is offline
spark plugs
what is the best spark plugs i should put in my 1996 svx
Old 09-01-2010, 04:40 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: spark plugs
NGKs are very well liked. Best you can afford as they're not the easiest to put in. Not hard, just a little bit of time.
Old 09-01-2010, 05:23 PM
Re: spark plugs
NGK Iridium IX in mine.
Old 09-01-2010, 09:22 PM
Re: spark plugs
Same here. 40k miles and still strong.
Installed in spring '03.
Old 09-02-2010, 04:55 AM
Re: spark plugs
NGK Iridium.
And you can install the in NINE MINUTES!
OK, inside joke.
Expect two hours for 1-5, and 2 hours for #6, the first time.
YMMV
Old 09-02-2010, 07:45 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: spark plugs
NGK Iridium.
OK, inside joke.
YMMV
I still cannot grasp what makes the #6 so hard. I had no trouble pulling the coil up and out of the way, and the chassis hole makes pulling the actual plug a breeze.
I actually put off doing my plugs for an extra 6 weeks from fear of the driver side bank, and afterwards it was like "that was it?".
Not saying its easy easy, but I never understood the trouble people have with it.
Old 09-02-2010, 08:45 AM
Re: spark plugs
After a problem with the #6 cylinder on the first engine in my Claret,
I got down to about 10 minutes for that plug after repetedly changing that oil fowling plug.
Practice helps speed.
Old 09-02-2010, 09:34 AM
Sov13t's Avatar
Sov13t Sov13t is offline
Re: spark plugs
Must be the girly hands
tee hee... jk
Old 09-02-2010, 10:12 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: spark plugs
tee hee... jk
Ha! I broke a nail the other day and only cried for 15 minutes. Girly........ pffff
Old 09-02-2010, 10:37 AM
Francis Francis is offline
Re: spark plugs
my god i did mine las weekend....WHAT A PAIN IN THE A$$$
NGK Iridium.
OK, inside joke.
YMMV
or maybe was it because i took a little longer than expected and ended with #6 using a simple head light to finish the job under the rain........couldn't help me either
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 09-02-2010, 11:01 AM
Re: spark plugs
LMAO!
Old 09-04-2010, 05:03 PM
dennyo dennyo is offline
Re: spark plugs
The hardest part of changing the plugs in mine was getting the ##2@@$% boot from the coil off the plug.The thing was hard as a rock and I used a pick to get the pieces out. That was 20 min. alone. The rest was a snap.First time maybe one hour+/- I bought a couple of boots for spares.
Old 09-12-2010, 12:39 PM
Re: spark plugs
i replaced all six plugs in 45 mins
Old 09-12-2010, 12:48 PM
Re: spark plugs
Slacker...
Old 09-12-2010, 01:14 PM
Re: spark plugs
for thr first time ever doing it that cant be bad
