Hey guys, I guess it is time to refresh the issue of the SVX's suspension, especially after all the recent mods that are now available.
In hopes that this thread will evolve to become a how-to-guide for racers, autoxers and engine modders. The subject definitely needs discussion. To start with, a small explanation of Understeer & Oversteer: - Understeer: It is the condition in which the vehicle does not follow the trajectory the driver is trying to impose while taking the corner because the effective slip angle at the front is larger than that at the rear, instead following a less curved trajectory. - Oversteer: It is the condition in which the vehicle is said to oversteer when the rear wheels do not track behind the front wheels but instead slide out toward the outside of the turn. Oversteer can throw the car into a spin. As a base rule, to have the less evil of the two (oversteer), the car needs to be softened from the front or stiffened from the back. But to what extent is this applicable on the "SVX"? So far, we have/had the following suspension components available: - Koni/GC; - Bontrager rear bar/endlinks/bushings; - PowerGrid front endlinks; - Strong-Flex complete car suspension bushings; - 15$ & 20$ mods from svxfiles. Now the debatable question is: How to successfully manage all these mods in the SVX in order to have a "harmonic", stiff and acceptable suspension? The specific requirements to know are: - Koni/GC: Konis are fixed, GC are variable. What is the correct stiffness for GC? - Bontrager rear bar/endlinks/bushings: Fixed - PowerGrid front endlinks: Fixed - Strong-Flex complete car suspension bushings: Variable in Normal and Strong. - 15$ & 20$ mods from svxfiles: Fixed. Choosing the ultimate of each will lead to instability and spins out of control. I know that through my own setup. With just stiffened struts (more than the Konis and the rear > front) and teflon bushings in the front, I can feel that my car will definitely spins out if I try a sudden right/left move at a moderate speed. The SVX is not the WRX nor the EVO. It weighs a lot in the front, so we cannot really compare it to either one. Furthermore taking into consideration the Automatics, 5 speeders, 6 speeders and the 6 speeders with DCCD control... We need to know what is the best for each setup. Huge subject, YES. We need to get this sorted out, best input I see comes from people who researched and experienced them in the past. Let us make SVXi better ![]()
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
Re: Suspension Talks: Understeer & Oversteer
I'm only aware of two people besides myself who have gone through the math to create a good combination of stiffness and balance (oversteer/understeer). You can throw conventional combinations of parts at a car and hope they come out OK, but that doesn't make sense!
My spring rates were selected for an autocross capable, yet comfortable ride, giving a tendency toward neutral balance with mild understeer for a shade of safety. The numbers worked out nicely! To buy a set of GC springs based on a combo shown around is crazy; they're absolutely customizable.
Disclaimer: The above post is on the internet. |
![]() Lee
SVXx2 92 SVX LS-L Silver 92 SVX LS-L Burgundy (structurally challenged with 2792 miles) 96 SVX LSi Red 92 SVX LS Pearl (Parts) 01 F150 4X4 Red (+6 with other members of the family) FREEDOM IS NOT FREE |
What rates are you running Rob?
They've been in for a while now! I think they're 385/315, but I'll take a look.
Here is an example of the PERFECT suspension..
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k ![]() |
A perfect suspension for me is a setup that can cause a maximum of 5% understeer and 25% oversteer.
Looks mean nothing really... And yes forgot the K-Macs....
i'm running 380/340 on my gc
415lb /385lb. for me... It still pushes a bit through corners (I do not have the rear sway bar installed yet) but breathe on the throttle and I can get the back end to rotate quite nicely
![]() I imagine with the rear bar it will be neutral/ slight oversteer through the corners with no throttle being applied...
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
Now we need to know the effect of the bushes along with your setup Bobby...
unfortunately my time in the garage has been minimal and the time I have had has been used for other things
The theory of transferring load at the rear to the outside rear wheel, does not work properly in practice, due to the majority of weight having transferred towards the front. Those pushing this theory are basing argument on straight line bump steer and the inbuilt understeer provided by manufactures, so that idiots can sleep at the wheel. Some negative camber at the front is also very effective, and provided not overdone can in fact actually improve tyre wear. Getting rid of soft mountings and bushes sharpens up the handling like nothing else on a cost for result basis. This is particularly so in respect of the steering rack and associated components. The very keen, should fit a rack from a four wheel steer JDM, which has a higher ratio. A resourceful driver will always prefer a touch of over steer and most certainly no under steering at the front end. The very serious go so far as fit a lightweight steering wheel, free of the inertia which normally kills feel. As of late I am aware that it will be considered that --- “you come off as the most self righteous pompous a-hole on the planet.” as a result of me presenting specific advice, but I do not give a damn. There may be some who appreciate sincere information presented honestly and based on genuine practical experience.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
Speaking of steering racks, how would one even get a 4WS steering rack? Any way to modify the regular steering rack to give it a better ratio, or would that fall into the "prohibitively expensive" category? Also, what about an sti steering rack? If sperry can retrofit sti knuckles on the svx, why not the steering rack? Any other ideas?
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
Wouldn't you want some softness in the front suspension to be able to "absorb" the tendency to slip? I mean if the front is also stiff, the car will slide, no? Quote:
I do not understand your reasoning. In no way did I suggest that the suspension should be stiffened. An anti roll device does not alter the verticle compliance of the suspension. Quote:
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() Last edited by Trevor; 04-22-2010 at 03:27 AM. |
