Old 05-30-2012, 08:08 PM
Dessertrunner's Avatar
Bulk buy on Cam pullies
Anyone have a interested in buying a set of these adjustable cam pullyes that baza found,
from here
http://www.ebay.co.uk/itm/Subaru-EG3...-/370606536907
I figure if we buy a couple of sets we may get a discount.
Tony
Old 05-30-2012, 08:25 PM
Re: Bulk buy on Cam pullies
We can get around the pulley adjustment with offset keys.
It is the inlet cam that needs an adjustable gear.
Old 05-30-2012, 08:29 PM
If we shave heads we effect both cams?
Old 05-30-2012, 08:48 PM
Yes,
Actually, all four.
Old 05-30-2012, 11:44 PM
To set the valve timing to what it should be, you need to be able to adjust both cam positions.
Old 05-31-2012, 09:24 PM
Yep.I heartily agree with what this esteemed statesmen has said! However since we need to have more than yep in the reply I will honor Him in a courtius and respectful way.
Thank you Harvey!
Old 05-31-2012, 09:32 PM
So we need what this guy has: http://wrxmodders.com/forums/viewtop...r=asc&start=15
Plus the sprockets. Wonder how much that would cost.
Old 05-31-2012, 11:31 PM
To quote the master.
Yep.
Old 05-31-2012, 11:35 PM
Yes those look the goods.
Maybe some body could make a set.
Old 06-01-2012, 05:40 AM
Snazzy. Obiously these wouldn't work with the OEM pulley removal tool though. Chain wrench it is!
Old 11-04-2012, 05:59 PM
subarvair subarvair is offline
I just noticed these on evilbay and came on the forum to find out what tuners thought.
So what's the consensus? Seems to me that to be effective, intake and exhaust needs to be separately adjustable. My build is 11:1 forged pistons, ported heads, modestly ground cams and long tube headers. Still using the OEM buckets. I don't remember if the cam timing was changed on the grind. Probably not.
How much benefit would there be?
Thanks in advance.
Mike
Old 11-04-2012, 06:19 PM
Yes those look fine. They will move both cams, so the adjustment will retard or advance the inlet and exhaust cams. Good for some fine adjustments.
One tooth is about 14.5*, so if it can be adjusted that far, it will be worth it.
To be able to alter both cam timings, we need both that pulley, and an adjustable gear on the exhaust cam.
Old 11-05-2012, 02:49 PM
dynomatt dynomatt is offline
You'll need both...an adjustable belt gear and one adjustable inlet cam gear.
That would do it.
I'd be in if somebody was able to organise both.
M
Old 11-05-2012, 03:03 PM
That would do it.
M
Don't know, but I think it would be easier to make the gear on the exhaust cam adjustable, its just a plain gear. The inlet has the rattle gears on it, still work the same.
Old 11-05-2012, 03:07 PM
Yes I'd forgotten about that. I think you're right.
M
