#421
Bought my new engine. Yesterday technically.
#422
Found the rad cap under the warning sticker bubbling and leaking, which hopefully is the *only* reason the Bordeaux has been overheating here and there on occasion the last few weeks. What are the odds that I can have a cheap fix for the first time ever?
![]() Ordered the new cap and should be here shortly!
1994 subaru svx le 112k |
#423
Took my '94 Pearl to get annual Utah safety inspection and emissions today-- passed with no problems. Whew! Now back to the garage for another year...
#424
Pulled my radiator so it can hopefully be repaired this morning. Is coolant usually murky or is this a pretty bad sign?
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
#425
Define Murky = Not crystal clear , very Cloudy , or milky white, or rusty brown .
#426
Kinda cloudy, but still quite green.
Um, "opaque".
#427
Collect some of it and see if it settles into water and oil layers.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#428
Ordered 225/45ZR17 pilot sports for $62 each off the discontinued tires list today.
#429
Great price!
1992 LSL ebony pearl 171k - Thank you Ron Mummert Reading Box of Wine Car 1997 Lsi 2007 WRX 5-Speed Manual, Gloss Red Vinyl Wrapped, Brz Seats 189K ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#430
Replaced the dash cluster to correct an inoperable tachometer. Volla, the car now has 30,000 less miles on it.
![]() Gene (I recorded both milage readings even though I'm not going to sell it)
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
#431
bought a door for my GF for $29 and took it home with the SVX
Jared 1992 dark teal SVX LS |
#432
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart Last edited by radarwhiz; 08-24-2011 at 12:49 PM. |
#433
I've also done that...dead simple.
#434
Took a dozen pictures of my dents, dings rust and so forth for 'the shop' to inspect. Will anxiously await hearing back... I want to go for the Swiss Ruby Mica Pearl #247 color... or however close I can get to a crimson red.
Yes, it really needs paint.... ![]() ![]() ![]()
1994 subaru svx le 112k Last edited by Subix; 08-26-2011 at 09:12 PM. Reason: e2 |
#435
Flew a bit too close to the sun, didja?
Re-entry is a *****.
