Master Cylinder Brace
Just wondering if anyone knows of something that would work for the SVX. This upgrade is a big bang for the buck with other Subarus so I would be interested in one for the SVX.
Here is a link to one made by GrimmSpeed for the Legacy/WRX ![]() http://www.grimmspeed.com/master-cyl...9-12-forester/ Someone with some metal fab skills could make some money off these ![]() |
Re: Master Cylinder Brace
Do you have stainless steel lines?
Given that the SVX's firewall is essentially a "boat bulkhead", the benefit of this brace is marginal, at best (same reason the SVX doesn't benefit from a shock tower cross brace)
Bill
Yesterday I had a friend push very hard on my Claret breake pedal while I watched the master cylinder.
He pushed both slowly and fast as if in a panic brake application. I REALLY don't think it moved 0.02". I could make a brace, but it sure looks like we do not need it!
I'm gonna have to argue with this, when I did the test for flex I had quite a bit of movement of my firewall. I may take this up to road to my neighbor that owns a fab shop and have him build one to fit.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
sending pm
That I do. I am looking to find more ways to improve my braking without breaking the bank. I know this works well for the newer gens with what I would assume to be less likely to flex firewalls. The hope would be the same improvement could be had here.
(again Bill, DO NOT TELL HIS WIFE! ![]() so we, (that would be me and Bill from NASA!) can test this further with an experienced SVX driver can check out several SVXi and quantify our results! ![]() NASA guys say quantify ALL of the time! ![]() More on this later, if the mystery guest shows up. ![]()
But that 5 spd will probably end up a DD 😉
The 5spd that's here is a cable unit, not hydraulic, so I haven't weakened the firewall by cutting any holes in it for a booster. Is everything tightened up well on your firewall? If anything is loose, it will obviously flex when applying pressure Bill (safe in the knowledge that his wife does not check the network...)
![]() The Racer sure could use a new set of slicks! ![]() Yes boys and girls, this IS called blackmail! ![]()
From a Business standpoint, there isn't money to be made. Might sell about 5. And as stated, the SVX firewall structure AND thickness is much more robust (as is just about everything) compared to all other Subarus.
Again, just sayin.....
http://www.subaru-svx.net/forum/show...90&postcount=1 .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 07-06-2015 at 04:15 PM. |
Part of me wishes that's just for laughs but I know better. Back to the brace. I am glad to hear the firewall is beefier than other Subaru models but I wish I could at least do a before/after comparison. If anything this will serve as a reference for any future searches. Last edited by theflystyle; 07-06-2015 at 04:52 PM. |
Let me/us know what happens,..
