Old 07-02-2015, 10:47 AM
Master Cylinder Brace
Just wondering if anyone knows of something that would work for the SVX. This upgrade is a big bang for the buck with other Subarus so I would be interested in one for the SVX.
Here is a link to one made by GrimmSpeed for the Legacy/WRX
http://www.grimmspeed.com/master-cyl...9-12-forester/
Someone with some metal fab skills could make some money off these
Old 07-02-2015, 08:52 PM
Re: Master Cylinder Brace
Do you have stainless steel lines?
Old 07-04-2015, 09:09 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Given that the SVX's firewall is essentially a "boat bulkhead", the benefit of this brace is marginal, at best (same reason the SVX doesn't benefit from a shock tower cross brace)
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-04-2015, 09:16 AM
Yesterday I had a friend push very hard on my Claret breake pedal while I watched the master cylinder.
He pushed both slowly and fast as if in a panic brake application.
I REALLY don't think it moved 0.02".
I could make a brace, but it sure looks like we do not need it!
Old 07-04-2015, 12:19 PM
bishop bishop is offline
I'm gonna have to argue with this, when I did the test for flex I had quite a bit of movement of my firewall. I may take this up to road to my neighbor that owns a fab shop and have him build one to fit.
Old 07-04-2015, 12:37 PM
I see that you have a 5 speed.
sending pm
Old 07-04-2015, 04:52 PM
That I do. I am looking to find more ways to improve my braking without breaking the bank. I know this works well for the newer gens with what I would assume to be less likely to flex firewalls. The hope would be the same improvement could be had here.
Old 07-04-2015, 06:34 PM
Originally Posted by theflystyle View Post
That I do. I am looking to find more ways to improve my braking without braking the bank. I know this works well for the newer gens with what I would assume to be less likely to flex firewalls. The hope would be the same improvement could be had here.
I THINK that another SVX Racer will be here tomorrow, (Bill, its Bill ) someone who Both races SVXi and owns several,
(again Bill, DO NOT TELL HIS WIFE!)
so we, (that would be me and Bill from NASA!)
can test this further with an experienced SVX driver can check out several SVXi and quantify our results!
NASA guys say quantify ALL of the time!
More on this later, if the mystery guest shows up.
Old 07-05-2015, 07:54 PM
SVXRide's Avatar
But that 5 spd will probably end up a DD 😉
The 5spd that's here is a cable unit, not hydraulic, so I haven't weakened the firewall by cutting any holes in it for a booster.
Is everything tightened up well on your firewall? If anything is loose, it will obviously flex when applying pressure
Bill (safe in the knowledge that his wife does not check the network...)
Old 07-05-2015, 08:11 PM
But that 5 spd will probably end up a DD ��
So, Bill what is Jackies E-Mail again?
The Racer sure could use a new set of slicks!
Yes boys and girls, this IS called blackmail!
Old 07-06-2015, 12:52 PM
From a Business standpoint, there isn't money to be made. Might sell about 5. And as stated, the SVX firewall structure AND thickness is much more robust (as is just about everything) compared to all other Subarus.
Old 07-06-2015, 01:23 PM
For that matter you could just cut out a section of SVX firewall from a scrapped one, sandwich it into place and put an extra four bolts in the outer edges.
Again, just sayin.....
Old 07-06-2015, 04:12 PM
ZIP-TIES!!! From 11 years ago.
http://www.subaru-svx.net/forum/show...90&postcount=1
Old 07-06-2015, 04:49 PM
Interesting idea. That sounds more feasible for someone like me to try.
Wow.....
Part of me wishes that's just for laughs but I know better.
Back to the brace. I am glad to hear the firewall is beefier than other Subaru models but I wish I could at least do a before/after comparison. If anything this will serve as a reference for any future searches.
Old 07-06-2015, 04:58 PM
Wow.....
OK, open your hood and have someone you trust push as hard as they can on the brake pedal whily you watch for ANY movement of the master cylinder
Let me/us know what happens,..
