WTB: EG33 Piston Left-hand side (#2,4,6)
Hello,
Looking for a single EG33 piston, for the LH bank. It will be stamped on the piston which side it is. cheers -Evan |
Re: WTB: EG33 Piston Left-hand side (#2,4,6)
Still looking.
New or used?
I'm open to either. I wasn't able to get new ones from SOA, so hopefully someone here has something!
cheers -Evan |
So do you want an A, B, or C?
If you look at the top of the block the three different piston sizes for the six pistons are stamped into the block.
I'll check this weekend, thanks!!
cheers -Evan |
bump, looking for a "B" size piston.
cheers -Evan |
Can the size be found on the piston itself anywhere? I don't have easy access to the block they came out of, but I have some extra stock pistons.
Its usually stamped on the center of the piston crown, at least it was for my EJ25 pistons. Haven't looked closely at my EG33 ones. If not, size "B" is 96.875 - 96.885mm (3.8140 - 3.8144)
I appreciate your response, these are proving tough to find! cheers -Evan |
i have what you need i believe
Found one. Thanks everyone.
cheers -Evan |
