Old 06-23-2013, 08:37 PM
Just got home from a week long vacation which included my cousin's wedding and then a camping trip with my parents and brother. The SVX did the 900 or so miles just great getting 25-28mpg.
Old 06-23-2013, 09:44 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Just did 4 cam seals, crank seal, inhibiter switch, installed factory fogs on the outback.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-23-2013, 10:17 PM
Just got home from a week long vacation which included my cousin's wedding and then a camping trip with my parents in brother. The SVX did the 900 or so miles just great getting 25-28mpg.
I will use this French word, "Vacation" because I am above you all, Peasants! My life is one of luxury!........................................... .................................................. ....................Oh, wait, that is some one else.............................................. ....................Sorry!
Old 06-24-2013, 09:52 AM
Gamesy's Avatar
Gamesy Gamesy is offline
coilovers on my outback sport
Old 06-25-2013, 06:28 PM
reberto reberto is offline
Switched it over from Castrol Edge w/Titanium 5w30 w/POS Fram TG filter to Mobil 1 Synth 5w20 w/Mobil 1 EP filter. So far it's stopped it's seep from the oil filter, and is running MUCH smoother than before.
Old 06-25-2013, 07:30 PM
Also fixed the a/c and did a 2 to 1 piece headlight conversion on the outback. Also scored some nice heated black 02' outback limited seats that are getting installed in the SVX.
Seth
Past subies:
Other toys:
Old 06-25-2013, 08:11 PM
Pleasepleasepleasepleaseplease take lots of photos during the install? My SVX is still in need of new seats, and I had to put my WRX seat project on hold due to a lack of $$$ and a job. Now that I've got both again, I'm ready
Old 06-26-2013, 12:24 PM
They fit in and the front tabs mount pretty good but the rear tab towards the console will need cut/new tab welded on. I do have a set of svx rails I was going to use but they wont work on the newer seats but they would on the older stuff pre 99'
Seth
Past subies:
Other toys:
Old 06-26-2013, 05:20 PM
Subachouli Subachouli is offline
Subaru Parts Guy
Installed the flywheel/clutch to the engine, assembled the frankenstein shift linkage, and swapped out the rear carrier assembly for one with a correct matching ratio.
Manual transmission goes in next weekend. Followed by hours of troubleshooting, I'd bet.
Needless to say, it's been an entire week of SVX daydreaming.
1994 SVX- 5MT, Deltaspeed, Stebro,Work VSXX
1994 Legacy GT
2001 Forester
2002 Impreza WRX
2005 Impreza WRX STI
Need parts?
Old 06-26-2013, 08:15 PM
Have you figured out how to do the wiring for the reverse lights, neutral safety switch, and clutch pedal switch? There is a pair of wires by the shifter that need to be jumpered as well.
Using the old auto wiring harness, and new plugs for the reverse and NSS, you can make a little wiring harness so that when you're putting the actual trans in, it's mostly plug-and-play.
What kind of pedal setup do you have? Hyrdo or cable?
http://www.subaru-svx.net/forum/showthread.php?t=57833
Old 06-27-2013, 05:52 AM
Why not just remove the shift lock unit? Then you don't have to jumper the wires.
'92 SVX LS Pearl White - 6mt
Old 06-29-2013, 07:41 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I relocated my gas selector switch. I used the coin holder insert.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 06-29-2013, 09:55 AM
Subaru Parts Guy
Wiring is definitely not my strong suit, but I'm pretty confident I'll be able to sort it all out. I collected parts for about year before taking on this project, so I have a few of everything.. like most Subaru owners. Spare harnesses, spare transmissions.. all that good stuff.
I've been using a print out of Huck's guide, Tom's guide thread, as well as a few threads I've been able to find on here, including the one you provided.
I got a little rough with my clutch switch and it broke while I was trying to mount it to the pedal. So I may decide to use the old 'remove the inhibitor switch and set it to neutral' method for now until I can replace it.
I had planned on taking my time and doing this conversion over the course of a year or so. A couple of months in, and I'm tired of looking at the car on jack stands in my garage, and I want to take my WRX off the road to overhaul the suspension. So I'm throwing the SVX together so I can enjoy it for a bit, and then I'll take my time and correct all the little stuff and make it the project/Sunday car that it was originally meant to be.
I'm using a cable clutch pedal box.
Funny story about that.. Using the search engine on this forum, I was able to determine the history of the parts for my swap:
I purchased a "swap kit" from "Bshade" in Lancaster from a car he parted out. He had purchased the car from "Marlettpat", who had it swapped by "Hocrest", who used a kit that was put together by "Tomsvx".
1994 Legacy GT
2001 Forester
2002 Impreza WRX
Need parts?
Old 06-29-2013, 06:18 PM
Got the pass. side seat fixed up to fit, just need to wire it for heat and notch the LR tab a cm. Also going to mount the heat switches above the ebrake handle. The seats are also dirty still as I got them covered in mud.
Seth
Past subies:
Other toys:
Old 06-29-2013, 06:36 PM
Seth, how is the lowest seat height in comparison to the stock seat? I know you likely won't have an issue, but for us taller people, IIRC any other Subie seat sits up higher unless you swap seat rails. Correct?
