Re: lower control arm replacement
Icing, (thread hijack) can bad end links cause the front end to vibrate slightly at high speeds, kinda like an unbalanced tire?
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
I don't think so. Do you feel the vibration in the steering wheel, or through the car, or your ears?
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
Only through the steering wheel. If I grab it real tight i can stop most of it. The funny thing is it's intermittent. It only happens some times, and when it does, it's at certain speeds. 0-60mph has nothing, but as soon as I hit 61, it vibrates. it goes away at 80mph. I think it might by my axels/CV joints, as I know those are on their way out
nothing to do with the sway bar...i dont have it installed on the car it is my trunk right now and i replaced the top mounts when i did the struts so idk
Jared 1992 dark teal SVX LS |
Tie rods maybe?
well we just got finished looking and we think believe it or not that it is the brake caliper...it is very loose like you can poke it with your finger and move it
anyone have any idea where i can a rebuild kit or just the bolt and bushings?
Front caliper rebuild kit is hard to find. Advance auto has them. Part No. 15156
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
STRIKE 2 not the caliper replaced it last night and it is STILL CLUNKING
![]() does anyone have any other ideas? i grabbed the tie rod and yanked hard up on it and it made a similar noise as to what im hearing but like i said i had to pull HARD do you think that could be it? or maybe even the exhaust? help ![]()
ok I will keep that in mind Nate thanks, but now i have another issue...since we changed that caliper out that brake now "scratches" it isnt a squeak but more like a scratching noise...i thought it might just be because the pads are just sitting in a different spot and have to wear down the rusted spots of the rotor but it has been a week and it is still making the noise... *SIGH*
