Old 03-23-2013, 01:40 PM
michael's Avatar
michael michael is offline
What Potholes ???
Broke my Outback in!
Wanted: Steering Wheel
Old 03-23-2013, 06:37 PM
Took the SVX out of hibernation today! And then made a complete tool of myself. The car started perfectly with a boost, let it idle for a few minutes and then drove to the gas station. As soon as I walked around to the pump I realized I'd forgotten my wallet. Then when I hopped back in the car I discovered the battery hadn't charged enough to start the car. ****.
Walked home (10 mins), got the Elantra and booster cables, boosted SVX and drove it home, walked back to gas station, drove Elantra home. I'll take it for a longer drive tomorrow and see if things charge up properly. If not the battery is under warranty.
It's so much fun driving the SVX again though. And quite tricky. I'm used to the Legacy now and the SVX drives extremely differently. Way more touchy throttle pedal compared to the Legacy, and also much more low end torque. All together it's a much different driving experience.
Old 03-23-2013, 07:25 PM
Hint. Get a jump start battery pack.
Old 03-23-2013, 08:06 PM
Earl posted a recommendation of a battery tender last year. I use it whenever I put one of mine on the sideline for a few weeks or more, and so far I like it too. Highly recommended: http://www.amazon.com/dp/B000FQBWCY/
Old 03-23-2013, 10:25 PM
bishop bishop is offline
Outback limited leather steering wheel, still working on getting the airbag wired up.
Old 03-24-2013, 06:40 AM
Chris_'s Avatar
Chris_ Chris_ is offline
Loaded the battery and started her after six months in garage.
svx my94 vtd EUDM
-custom Spax coilovers
Old 03-24-2013, 11:48 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Cool Re: What have you done to your SVX (or other Subaru) today?
Wow!!! man what's up with those "back to the future wheels"
Is there enough air getting to your brakes???
Old 03-24-2013, 02:20 PM
Chris_'s Avatar
Last touch for that futuristic look of svx . First I hated those but now I have really started to like those. And I dont think that cooling is issue at all.
svx my94 vtd EUDM
Old 03-25-2013, 07:31 PM
AlcyoneSVX's Avatar
Alcyone Silver Contributor
Took the "Pearlie" to Vegas this weekend. First road trip in it since I bought it (three weeks ago). Drove like a dream! And 28 mpg!
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 03-25-2013, 08:25 PM
Even better, got a brand new battery for free under warranty. I'll get a tender for next year though, unless I start the tear down in which case maintaining a battery will be irrelevant.
Old 03-25-2013, 08:28 PM
I noy mentioned the battery pack so it would have saved you a lot of driving and walking time. I keep one in my trunk.
Best $59 I spent in years.
Old 03-25-2013, 09:23 PM
Or the Battery Tender Plus
Best product I have ever used to keep my battery charged between drives.
And for jump starting anything, I keep this 900A Battery Pack in my car. I has started 3 totally dead cars in succession without missing a beat. During an emergency, this will keep your cellphone powered for weeks.
Old 03-26-2013, 01:11 PM
EdWindows's Avatar
5spd + coilovers = win :D
Bench tested my new double-din receiver and HKS CAMP configuration so I can listen to audio from my Zune while viewing the CAMP output all while the car is in motion.
Old 03-26-2013, 05:48 PM
Scimitar Scimitar is offline
Wow! And I thought I was the only one who still used a Zune! Do you have it hooked up through the AUX port or do you control it through the head unit?
Old 03-26-2013, 06:26 PM
redlightningsvx's Avatar
Collision Refinishing Tech
I have one of the zune hd's, had it for years and still use it.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
