Re: Heated seats
Does this seat heater switch need to be purchased from a Canadian dealership?
Does getting the stock heater switch prohibit one from getting an aftermarket heater element that is actually installed in the car seat? |
Re: Heated seats
Using the Canadian switch with an aftermarket heater element is exactly the idea. The Canadian heated seat switch is to make it look as factory as possible.
Re: Heated seats
And it should be able to work with most, if not all, aftermarket or even other OEM Subaru seat heater elements. I believe Mike Davis was one of the first to do this using a Canadian switch and elements from 2nd gen Outback seats. The switch mounts in place of the "coin holder" on 92-95 US SVX. On an OBD2, you would need to relocate the OBD2 scanner port or figure out some other solution. |
Re: Heated seats
I have had the canadian seat heater switch sitting around now for a number of years - from what I understand it is a simple on/off setup, what I want to know is - is there a factory timer somewhere that turns off the heater or do you have to turn off manually ?.
Does someone have a wiring diagram of the setup, as I think you would also need a relay to switch the high current from battery to heater core ?. Also what size fuse is in the system - as this will determine the wattage of the heater. TIA
