Old 01-14-2013, 01:23 AM
Originally Posted by steveherman View Post
Maybe we can get a few people together to have some wings... or something.
If we're playing that game...
Old 01-18-2013, 02:54 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
And before you guys ask:
Check engine is from faulty TPS (installed new one today), stop lamp from 3 LEDs out in trunk LED bar, and ABS because I took the fuse out because ABS is for chumps
actually my solenoid got stuck and I removed the fuse to shut it up, and I left it out because I prefer no ABS in snow
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 01-18-2013, 05:41 PM
Changed the oil in the Legacy, cleared its persistent O2 sensor code. Thank god for AccessPort, the car runs like garbage when the code is present.
Old 01-20-2013, 12:51 AM
Crash_Bandit Crash_Bandit is offline
Finished replacing the transmission in my 96 after it suddenly gave up. Learned how much fun that was. Now I need to learn how to rebuild a transmission so I can have a nice shiny one to match the engine that's at the machine shop.
I need to hurry up on my restoration project so I won't get caught without a car if this ever happens again.
-Ash
96 Polo Green - Daily Driver
92 Teal Green - Restoration in progress
Old 01-20-2013, 01:25 PM
reberto reberto is offline
Tried replacing my PCV valve. Broke the hoses for the idle air controller in the process. Can't get to where the hoses need to go to be reconnected (the smaller one I can't get to), and the intake isn't willing to come off. SO! In the shop it goes :/
Old 01-22-2013, 03:09 PM
Old Davy's Avatar
Old Davy Old Davy is offline
Been driving the snot out of it today in our Hinterland daytime temps of +3 F ( w windchill pegged at -14 F.
Warm it up 20 minutes, slip into those heated leather barcalounger seats w 75 F breeze toasting your tootsies, crank up the tunes...and go play in the snow.
These new Firestone Winterforce snowshoes grip the straights and curves like a mountain goat, I can't make the rear swing out and the ABS barely comes on coming to a stop - sign or panic.
1997 Ebony Black Pearl LSi, 80k miles (129k kilometers), JDM clear corners.
1994 Laguna Blue Pearl LSi, 149k miles (249k kilometers), blown tranny, likely using bits and selling as donor transplant project.
2006 Newport Blue Outback XT Ltd 117k kilometers, lowered 2.25" on OEM Legacy GT suspension.
1994 Emerald Pearl LSi w 2006 WRX 5 spd manual.
1997 Laguna Blue LSi, 46k miles (73345 Kms). One owner 25 years, always garaged, pampered and 9/10 showroom condition. Possibly the last Canadian spec Laguna ordered #100134
Old 01-22-2013, 09:02 PM
Tapani Tapani is offline
Replaced the RH fron ABS sensor - the old one generated a nice sine wave, but it had an internal ground fault - I tore it open a bit and cut the grounded connecting flat "wire" - it was not the harness, but an internal issue. So I had to order a new one.
Now the ABS works again :-)
The weird thing is, the ABS did not switch off automatically, but operated really dangerously with the light and code 6 on..... The pedal was hard and when pressed with force the RH front brake was not there - it pulled STRONG to the left. I had to pull the fuse to drive further and wait for the part from Colorado :-).
So I guess the self diagnostics do not know exactly how to respond to a "good" signal with a ground fault. The resistance to ground was only 3-4ohm in the defective side.
Tapani
Old 01-23-2013, 06:47 AM
Huskymaniac's Avatar
Uses the ignore feature
Yesterday, I replaced a power steering o-ring in 11F temps. Last night I plugged the car in. The -10F temps this morning were too much for the 400W block heater. I'm sure it helped but the temp needle didn't move when I started the car.
Tony
Old 01-31-2013, 07:51 AM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Installed my new Optima Bluetop the other day. Now it starts when it's less than 20 degrees out!
1000 Cranking amps, 800 cold cranking amps. Way more than enough for this car! It turns over soooo fast now...
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 01-31-2013, 08:15 AM
theflystyle's Avatar
what kind of radiator is that and is that just a blue painted PS reservoir?
1994 SVX LSi
2008 Legacy 3.0R
Old 01-31-2013, 08:59 AM
Nice rad mount and fan support.
Old 01-31-2013, 09:31 AM
SVX8588's Avatar
Yeah, I painted the reservoir and pulley blue when I rebuilt the power steering pump. Check my sig, that's svxfiles' 2-row, all aluminum, custom built radiator.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 01-31-2013, 09:32 AM
SVX8588's Avatar
Thanx
Bobby had lots of good things to say about you when I bought it from him!
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 01-31-2013, 10:04 AM
Thanx
Thank you, That is always nice to hear!
Old 02-06-2013, 06:44 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Had safelight replace my windshield today
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
