Old 04-02-2012, 11:48 AM
Originally Posted by huck369 View Post
Check your prank pulley.....
No April fools, sounds like his crank pulley is separating....
He's only stating what you typed
Old 04-02-2012, 12:32 PM
Oops...fixed it....
Old 04-02-2012, 01:05 PM
Green1995SVX's Avatar
Nice. Welcome to the club.
What kind of 5-speed did you use?
The transmission is from a 2003 forester. It's actually the transmission that was in Phil Gantz's turbo SVX. The person who bought that is upgrading to a WRX unit, so I made a deal for this one. I went with an ACT light flywheel, spec stage 2 clutch, and a kartboy shifter as well. The setup works great!
I had swapped my first SVX back in 2004 using a smallcar kit, and in my opinion it basically ruined the car. It was so incredibly full of suck. With a real crossmember, and no "rigging" it is fantastic in this car.
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-02-2012, 01:08 PM
Mike
Nice. Pull clutch or push? Any driveability issues with the lightweight clutch?
Old 04-02-2012, 01:11 PM
It's a non-turbo push clutch. It was difficult getting used to how fast it revs, but now that I am used to it, I like it.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 04-02-2012, 01:24 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
I want a 5-spd..that would make me want to keep the car
Old 04-02-2012, 08:45 PM
Today I got my SVX inspected for the first time in 4 years, and I got a set of tires installed (Michelin Pilot Sport 3).
Also snapped a couple of pics.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
fzftw's Avatar
fzftw fzftw is offline
Just dip a toe!
Changed my front swaybar end links. And noticed that my right front strut is leaking badly.
-Brian
Current fleet:
89 D21 2wd
91 XT6
93 D21 4wd
95 SVX LSi
02 Windstar Sport
03 CL500
03 Avalanche NF
07 RDX
08 Outback
10 Outback
10 Murano
12 Accent
15 STi
Old 04-03-2012, 01:22 AM
aust92pearl aust92pearl is offline
i just finished installing some "new" (to this car ) older 6x9" speakers in the back of my pearlie
wow what a pita
also tried to fix the antenna as it doesn't go up and down
removed it and jumped to straight from the battery
turns out the motor is dead ... it just makes a singular click noise and does nothing
so i went old school (removed the inner part of the motor ) so now i have to pull it up or push it down
atleast i get good reception now
Old 04-03-2012, 05:07 AM
Actually started mine up and took it for a spin...fist time it's been out of the garage since last fall
Was nice to drive it again
Old 04-03-2012, 09:05 AM
my antenna used to do that and it was worn out contacts on the limiting switches in the case. if it clicks the motor is working but it senses that it is at full travel and won't go any farther. just cleaned them and scuffed em and now it works fine.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 04-03-2012, 03:57 PM
i cleaned the entire thing out , and scuffed up the contacts and still nothing
il just live with pulling it up and pushing down untill i can be bothered to swap the one from the other car in
Old 04-03-2012, 07:13 PM
Chuckls's Avatar
Designated Asshole
I just took the whole regulator/motor out. I don't listen to the radio much, so when I DO use it, the internal antenna works fine for picking up signal.
Old 04-03-2012, 08:20 PM
Got some Conti DWS's mounted on my old stock LGT wheels and put them on the FXT. They are going to be much easier to clean now.
Old 04-04-2012, 08:50 AM
radio signals are not very strong here , so every now and then at the bottom of hilly areas it drops out of reception , its not so much of an effort for me to pull it up and push it down ....
kinda makes it old school
