#301
What I did to my SVX this weekend: Drove it. Took the silver on a 250 mile jaunt. Smooth and strong. The old gal still pulls like a freight train. (Gotta fix that rattling heat shield, though.) Frosty AC in the 97 degree heat.
dcb |
#302
You are selling it? Why?
#303
Venturing slightly off-topic:
After waiting for three years to own the Silver, when would I ever be inspired to drive the Pearly?
#304
#305
What's normal about that Pearly? I think the sunroof is stock...
#306
More like, what did my son do for the SVX today. Finally, some decent rear struts.
Gene
#307
Got the SVX aligned for autoX duty yesterday and today I'm bolting on the race wheels and tires for a two day autoX event this weekend. Tomorrow, some brake work and clean-up before I leave.
On the Legacy, I'm replacing the cabin air filter so she doesn't feel left out
Down to none |
#308
Painted the calipers yesterday:
And this is my "factory looking" power mode mod. Had an spare switch cluster so I put it on the right side. The parking light one is for Power Mode, and the other is still free for something in the future. Now I just need to see if I can paint them to label them different:
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
#309
Mine is the thumb button on the shifter . The amazingly useless manual button's been moved under the ashtray.
#311
Well I replaced the leaking power steering pump from my burgundy 92 with the pump from my 92 parts car..only to find out that it is also leaking from somewhere else that I have not investigated yet.
On a more positive note I picked my ebony 96 up the other day from they paint shop. And no I did not get a Maaco paint job either. Spent $5,000 and well worth it. They took every single teenie tiny dent out and painted my windshield wipers and the guy even took my impossible to remove water spots off my windows. The paint job has a lifetime warranty for anything weather related like oxidation. I'm super happy about this!!!
Meow |
#312
I bought mine.
Ok, It was yesterday, but hey...close enough. I'll post more later, but duty (work) calls... ~TEck |
#313
Replaced coil #2. Fixed misfire. Smooth driving.
#314
Replaced the rear diff fluid and did an oil change. Adjusted the parking brakes. Got her washed and filled with a tankful of premium and some injector cleaner for the 3 hour journey to my first autoX since 2008 and only the second time in my 5 speed SVX.
Wish me luck! Todd
Down to none |
#315
Glad it solved your issue.
