#106
I will make a thread, I just don't have time to right now. I'm not 100% what's wrong yet but I know the engine's f***ed. Focusing on fixing it now more than finding out exactly what's wrong.
#107
ya understandable. I think I have headgasket that is slowly going most of the time I dont have any trouble but once in a while it will start getting hot and when I open the rad cap its low. Not too many reasons for it to get low.
#108
It could be an innocent leak. Any smoke coming out the back ever?
#109
No smoke ever. I dont need to fill it very often either running it every day maybe once a month or every 2 months. I replaced my rad cap a couple weeks ago and it seems to have taken care of things. I hope so.
The day I went down to your place I ended up filling the rad at a service station before I left tampa. |
#110
Used the mothers powerball headlight restoration kit. My headlights were not bad enough to need sanding but I just used the polish and they look much better!
#111
Yesterday, I found that the ABS controller and its respective monster harness plug weigh about two pounds.
My basement weighs about two pounds more now. ![]()
#112
Paid my road TAX here Japan today & maybe
install my S/S brake lines tomorrow if I can use the lift at the Auto Hobby Shop on base? Will take pictures? Can anyone suggest brake fluid? Thank you all you diehard SVX owners and happy drivers!! Sincerely, Tomodachi |
#114
Do one wheel at a time, to make sure you get the routing right. I always use a fully synthetic Valvoline DOT 3-4. I am not sure what is available to you on the base. ![]()
#115
I cleaned and waxed the exterior and cleaned the entire interior and I also used some Crystal View headlight restore.
Check it out. ![]()
1992 Pearl White LS-L "Ruslana" #4946 - 180k on body, 95k on engine. Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint. †"War doesn't determine who is right, only who is left"† Work to be done: Tinted windows, clear/LED tail lights, tailbar mod, "Power Mode" mod, Supertone horns, clear corners & headlight lenses, 2 pc splitters or custom bumper, Alcyone side skirts, TruSpeed Stage III SVX Intake, Hydra, 4.44 tranny swap, JDM auto folding side mirrors, engine rebuild, super charger, STi seats, bone leather interior /w SVX emblem, dash overhaul, SVX decals, paint (stock color). Total cost?: 22k ![]() |
#116
Installed a new Ecutune Rom in my TCU, but ran out of daylight before I could get the TCU reinstalled in the car.
#117
A lil' vac and shampoo work, and then I emptied the catch cans.
Let's just say I'm glad I didn't go for an AOS! ![]()
#118
Oil change. Got a new air filter (fram). Had plans to wash but didn't happen.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black 92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho ![]() |
#119
Unless you are racing or driving down steep mountains at high speeds I don't think you will get DOT 3 regular fluid even close to the boiling point.
#120
Valvoline DOT 3 & 4 Brake Fluid Valvoline® DOT 3 & 4 Brake FluidFor all ABS, drum or disc brake systems requiring DOT 3 or DOT 4 fluid Compatible with all braking systems requiring a DOT 3 or DOT 4 fluid Mixes well with conventional fluids High dry boiling point up to 480°F reduces the risk of fluid evaporation and possible brake failure Low-moisture formula provides excellent vapor lock protection Maximizes ABS performance Ideal for hydraulic and disc brakes Surpasses specifications SAE J1703, FMVSS No. 116 and DOT 4 Motor Vehicle Brake Fluid Minimum wet boiling point is 311°F
