WTB: Nice set o' Lug Nuts
Like the title says. Looking for a nice OEM set... not too beat up. I've looked at the ones on ebay:
http://cgi.ebay.com/ebaymotors/NEW-C...Q5fAccessories but not sure if they will work?! Last edited by dbarnblatt; 03-04-2010 at 10:41 AM. |
Re: WTB: Nice set o' Lug Nuts
for factory or aftermarket wheels? If you're sticking with the OEM wheels you need to use factory lug nuts. If you're going aftermarket then those eBay ones are fine.
OEM... Thanks.. I'll fix my post.
Why exactly is that?
http://cgi.ebay.com/ebaymotors/20-LE...item1c0c00c2ad Last edited by Blacky; 03-04-2010 at 05:47 PM. Reason: wrong link |
I have a set for sale. $20 plus shipping
The OEM lugs have a collar and washer on them, which is meant to provide the clamping force against the wheel. The cone types nuts will do the job, but are certainly not the recommended hardware to use.
Ok I see what you're saying. I have a spare set of the oem ones that aren't as shiny and nice as the cone type ones that are on there. I've been wondering if there was a difference. I think I'll put the oem ones on. The rims are in such sad shape that I doubt it'll make a difference in terms of looks.
