Old 09-19-2008, 02:37 AM
pearlm30's Avatar
pearlm30 pearlm30 is offline
i can not get the tranny and engine to seperate
Replacing the trany, but I cant get them to separate, got all 4 TC bolts and 2 bolts and 2 nuts that hold the engine and trany together, also took the starter out. I pulled,shaked and lowered/raised the trany jack, but they just wont separate
Any tricks to separate them? If I need to pry them, where do I situate the pry bar?
Thanks for the help
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 09-19-2008, 08:01 AM
svxpert svxpert is offline
Re: i can not get the tranny and engine to seperate
<<I pulled,shaked and lowered/raised the trany jack, but they just wont separate
Any tricks to separate them? If I need to pry them, where do I situate the pry bar?>>
well, the two 14MM nuts on the engine mounts need to come off. then you can raise the engine just enough to clear the mounts. this should start to separate the two.
Old 09-19-2008, 08:31 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
You've disconnected the electrical harnesses, right?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-19-2008, 08:35 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
I've used a hammer and chisel to start a crack big enough for a screwdriver... then work that big enough for a pry bar...
Old 09-19-2008, 12:41 PM
pearlm30's Avatar
I went back and shake and pull some more, they finally opened up a very small crack, so small that I had to use a gasket scraper to make it big enough to fit a flat screw driver in it, then pry some more then used a big flat screw driver then pry bar Took me more than 2 hours
This is the worst part of taking the trany out. Now I have to figure out how to seat the TC.
Thanks for all the suggestions.
Old 09-19-2008, 12:50 PM
Hocrest's Avatar
  1. Put it in as far as it will go.
  2. Use a screwdriver in one of the tabs where the flexplate attaches as a handle and spin it clockwise 4-5 times
  3. Slowly turn it counter-clockwise while pushing up and in
  4. Repeat the CW spin, CCW push till it is fully seated
Old 09-19-2008, 01:07 PM
After you CAREFULLY do what Hocrest said, look closely to see that the torque converter mounting pad is set back into the bellhousing.
Roughly having as much pad sticking out, as is setting in.
Old 09-19-2008, 07:42 PM
pearlm30's Avatar
Hopefully I did it right. If the TC is not seated in right, would the flex plate come in contact with TC and you wont be able to turn the TC?
Would find out tomorrow if everything goes well.
Thanks again everyone
Old 09-19-2008, 08:34 PM
SVXRide's Avatar
I believe the problem you'll have if it isn't seated correctly is that you'll trash the front pump....
-Bill
Old 09-22-2008, 09:45 PM
pearlm30's Avatar
I did it!!! Now I know how it goes as far as the TC seating properly. No hard, just need to practice a few times. Thanks again everyone
Old 09-25-2008, 07:07 AM
subbieatnz's Avatar
subbieatnz subbieatnz is offline
i took my motor out of my svx and its was so easy i couldnt get over it lol. i just lifted it out by my self with my engine crain. even my lil ea71 blocks were harder to remove.
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired
1989 Vortex 6 Maroon
1983 RX Silver Grey
1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration
