Coilovers for teh BEAST!!
I am returning to my roots within the next couple weeks. I built a set of coilovers for another member recently and I cannot help myself. I order my springs&collars and I am waiting to hear back from Mychailo about the konis... Ah I cannot wait to be back on coilovers I will post pics of the process of building the struts and installation
Tom |
Soon it will make your sig smaller to only list the stock parts instead of the mods
what stock parts??
tom |
SLACKER!!! BAHAHAHAHAHAHAHAHAHA,HAHA,HAHA,HA,HA, ha, snort.
With this mod, you'll be ready to hit the road racing track. Let me know when you want to go, and I'll find an event. First time out, you'll need to go with a group that provides instructors. Probably best bet would be a PDA event at Pocono. Once you get a taste of it, you will be an addict.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
I think Mychailo is in Japan right now.
i thought he was going in April?? Crap... do I really need to order them from classic garage?
Tom |
I could be wrong, but I thought he had already left. BTW how much for a set of koni/ GC's?
coilovers are about 400 shipped and if I get the konis from mychailo they are 630shipped... classic garage is 680+shipping
Tom |
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 04-09-2007 at 09:04 PM. |
Mychailo, can you drop me a pm or give me a call about the strut mounts and helper springs? Thanks. -Bill
Had em built for over a week and I just got them installed tonight... Riding 1.5" lower in the front and .5" lower in the rear... rock solid... Rides on rails baby!!! I also kept the stock camber adjustments so I have just the right negative camber I want... All smile here
Tom |
Nice!! No problems with the lower ride height and those 18" rims and tires? -Bill
no, I was concerned about that but once I let her down.... it looked too damn good to bring it any higher
Tom |
-Bill
