What to do with cooler
So, now that my auto box is being thrown to the wayside my transmission cooler in the PWR radiator will be unused. So i was thinking, could i re-purpose it to cool other fluids? What about running the engine oil through it?
'92 SVX LS Pearl White - 6mt |
Re: What to do with cooler
I had been wondering the same exact thing the other day. Seems like a waste.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
Engine oil sounds risky. Why not sell the PWR and just re-install an OEM radiator? You could get back some of the money you spent on the swap. I'm sure someone around here would buy your PWR radiator if the price were reasonable.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Why would he want to get rid of the All aluminum rad? That's the main reason of the PWR, not the better aux cooler.
power steering ??
Power steering doesn't get very hot. I think you would actually be increasing it's temperature by running it through the rad.
Block it off and forget about it, there isn't much use for it now.
With high pressure hoses,
(like Power steering hose) and good fuel injection clamps, I do not see it as a problem. ![]()
The STi has a coolant/oil heat exchanger from factory.
removed by user
Ahhh Shamus..... How many times must I tell you? None of that stuff will ever make your car faster than, or handle better than mine. Jealousy is a stinky cologne my friend.....
oil is risky. i see no need to "cool" the oil unless you are running F/I. just too much risk involved without much reward.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it. |
ummm, F/I is turbo or supercharging an engine.
Thread Tools | |
Display Modes | |
