#31
This link will be helpful: http://forums.nasioc.com/forums/show....php?t=1201152 Last edited by SVX_MY_BABY; 06-13-2007 at 02:06 PM. |
#32
-Stock R160 can be used without changing the gear ratio due to change in 06 that makes the ceneter diff a 1.1:1 vs the old 1.0:1
there you go, if thier info is accurate, the STi does have a 1.1:1 reduction in the transfercase. So the final drive *is* 3.9, but they do an initial 1.1:1 reduction to lower driveshaft speeds and then a 3.545 rear diff |
#33
Nice...if my 5spd ever packs it in I'll be looking for a USDM 2006+ 6 spd!
#34
One notes that the 2007 is different than the 2006 so, research that.... The ratios are certainly a hell of alot better
#35
Re: 6 mt
I need to keep this stuff in mind for later. Got to get up the money.
1992 Subaru SVX LS-L #5045 Dark Teal 1992 Subaru Loyale Wagon Gray (SOLD) 1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD) 1969 Subaru 360 Deluxe Ivory White 2005 Subaru Impreza WRX STi World Rally Blue 1993 Subaru Legacy L Wagon Teal Metallic (SOLD) 1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl [SIGPIC][/SIGPIC] |
#36
Re: 6 mt
Hello,
I have a question about the 6spd swap. I converted my svx from 5mt to 6mt sti. When i had the 5mt installed , it was very loud inside the car. While driving, you heard the transmission. It was like a dogbox but it ran fine. Now, the 6spd is even louder, like a truck. ![]() Did you cover the shifting gate with something? In this pic , there is a rubber boot installed. http://www.redlinegoods.com/images/F...install-04.JPG Could it be the reason for this problem? Thanks ![]() |
#37
Re: 6 mt
Also, at least in my case, I know that the trans has a good number of miles on it, so the bearings and stuff inside the trans are getting to be whiny just due to wear, so I think that contributes somewhat. There is a heat shield between the trans and the shifter area that is frequently deleted in m/t swaps. That also probably contributes a little.
#38
Re: 6 mt
True story..yours is pretty loud.
http://i840.photobucket.com/albums/z...93705d9zzz.png |
#39
Re: 6 mt
I'd like to think mine is fairly quiet. I'm currently working on a plate for the stock rubber seal on the shifter. I'll put it in my thread when I finish it.
'92 SVX LS Pearl White - 6mt |
#40
Re: 6 mt
I recently made one of these;
http://www.subaru-svx.net/photopost/...8&limit=recent Now lets see if my link works for you guys. ![]()
#41
Re: 6 mt
That's a good idea actually. Bolted down, or glued/sealed? I wonder if it would work as well if I made it out of something thinner and more manageable to me. Have you experimented with any rubber boot-type things under the actual shift boot?
#42
Re: 6 mt
Yes, you should have a rubber piece like this that seals the the transmission tunnel. In the STi it is held in place by rubber tabs, you'll have to invent a way to seat it on an SVX.
#43
Re: 6 mt
Aluminum diamond plate, bolted in. Upper leather boot.
#44
Re: 6 mt
Mine sounds like this
http://www.google.com/url?sa=t&rct=j...UKcU3Ss_uycUcg |
#45
Re: 6 mt
Hi,
I used the automatic plate and modified it, it looks nearly the same. But its still very loud in the car (transmission and clutch noise). I will try to get this original subaru rubber boot, which you can see @1:45min in this video: |
