Old 08-24-2011, 12:48 PM
radarwhiz's Avatar
Fairmont State University
Gauge Cluster swap
Here's the how-to and photos to replace individual gauges in the gauge cluster.
First remove the cluster (that's pretty straight forward)
Unclip and remove the clear plastic cover (red arrows show tabs to unclip) pic 1+2
Remove screws in pic 5 and then unclip tabs (pic 3+4) and remove black cover
Be mindful of the small filament still holding them together (green arrow)
Remove the 4 screws shown in red (speedometer) and the gauge can be pulled out the front of the cluster. This can be done with any of the gauges. There is nothing to unplug as the screws are what conducts the signals to the gauges.
Now the gauge out of the cluster. As you can see, this works with any of the gauges:
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 08-24-2011, 01:18 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: Gauge Cluster swap
Really? I assumed it would be a PITA and have avoided replacing my "D" light. How easy is it?
Tony
Old 08-24-2011, 01:36 PM
Earthworm's Avatar
Meow!
There is a separate how-to containing instructions on removing the trim around the instrument cluster.
Old 08-24-2011, 01:37 PM
radarwhiz's Avatar
What he said
Elazar
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 08-24-2011, 01:51 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
The bulbs can be replaced without taking the gauge cluster apart. The gear selections are the 7 black twist knobs on the back center (Photo 5). I have plenty of bulbs left over from the old cluster if you need one.
Gene
Gene and Ben
Old 08-24-2011, 02:15 PM
Gene
Yeah but you still need to take the cluster out. I found the writeup. Seems like it could take awhile. I'm guessing "D" and "3" are the ones that burn out. If I get brave and decide to give this a shot, I'll PM you about the bulbs.
Tony
Old 08-24-2011, 02:32 PM
If u want to remove or cover the PND123 because it is now 12345 <LOL> 5 speed How do u do that?
Old 08-24-2011, 02:37 PM
Easy, you take it apart to this stage:
(top pic) only without taking out the gauge. There is a little clear plastic panel that has the PRND321 printed on it that just pops right off.
Old 08-24-2011, 04:05 PM
zaueugen's Avatar
zaueugen zaueugen is offline
im working on making mine purple, i bought led's 9smd bulbs for the rpm and mph clusters.. the problem is 9smd takes too much powwer ffrom the others because they dont all light up when i plug in the cluster. for the fuel and temp gauges i bough led bulbs with just 1smd.
Old 08-24-2011, 07:01 PM
lsupcar lsupcar is offline
Have you tried taking the speedometer apart further? My speedo is reading slow with an accurate odometer, and I am wondering if the speedo can be repaired.
Bill Z
Old 08-24-2011, 07:17 PM
I have all white gauges. Did he ( PO) change them? OR did the 1994 come with white faces?
Old 08-24-2011, 08:18 PM
PO changed them. PlanetSVX.com (AKA Dayle, AKA Motorsport Warehouse in AZ) used to (maybe they still do) sell white face gauges. They call them EURO gauges. I think the gauge cluster is still basically the same though.
Old 08-25-2011, 07:32 AM
Earthworm's Avatar
Meow!
Bill Z
Is it consistent or speed dependent? (eg. always 5mph or 10%)
If it's consistent you could move the needle. If not then make sure the speedometer is screwed in tight (4 screws).
Old 08-25-2011, 11:47 AM
bwb3's Avatar
On the warning light bar aross the bottom of the cluster, I noticed there is a green Econ light next to the Power green light. I have never seen this light up on my car. What gives???
Gene
Gene and Ben
Old 08-25-2011, 01:12 PM
Gene
Euro/Aussie/JDM leftovers...
Display Modes
