Turbo Justy Project
I recently purchased a cheap 93 Justy 4WD and am in the process of modifying slightly. The engine is going to be pulled next week after I return from a business trip and rebuild! There is a bit of custom welding and piping to be done. I will keep you all posted if you are interested in seeing a silly Justy sleeper
![]() ![]() I thought I would share some photos The Justy The Small 1.2L engine (yes 3 cylinders) the engine bay has a lot of room compared to an SVX or others. I will be using a IHI RBH5 VF4 that will be put on this bad boy. Small and lower PSI, should be a perfect choice for the small 1.2L Feel free to post comments, suggestions and heckling.
Re: Turbo Justy Project
Sounds like a fun project. I kind of like those Justys.
1992 LSL ebony pearl 171k - Thank you Ron Mummert Reading Box of Wine Car 1997 Lsi 2007 WRX 5-Speed Manual, Gloss Red Vinyl Wrapped, Brz Seats 189K ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
Neat. Post some more pics, I want to see how this 3-cyl engine is set up.
I plan to! soon as I get to rigging it up. Hopefully with in the next month it will be ready to go.
Engine is out, now to start the fun.
Dang, a 9-valve engine. I'm gonna go ahead and bet there aren't too many of them in the world - at least, not in cars. Subscribed.
Does your car have the CVT? They've always fascinated me. I rented a Nissan Maxima that had one, and I thought it was way cool, but I'd really like to drive one of the Audi CVT's that do all the "lookit me, I'm pretending to be a box full of gears" tricks.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
No it is a 5spd. The CVT were notorious for failing (mostly due to poor maintenance) so a lot of them are not around. Possibly a good idea just bad timing. I am aiming for 100hp (or as close as I can get
This is such a bizare project. I am facinated. A great Grassroots 2013 project.
Gene
I got the car for 700 dollars or so with the intentions of being a daily driver. Well shortly after purchase it developed a knock. I figured I'd pull it and add to it. That turbo came off a mid-late 80's subaru and is low PSI.
just in case you havent found them, http://www.dustysjustys.com/home.htm has a lot of good info and can get parts for these cute little boxes.
just realised your in keizer, hopefully ill get to come take a peak.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
Now hook it up to that funky clutch tranny setup. Clutch less CVT
Get John on the line and subcontract a polish job on that distributor. Ha!
Neat project. ![]()
I shall have to have John detail it, I need the engine bay to look immaculate. The piping actually looks easier then I first expected. lots of room in the front there. The exhaust manifold shouldn't be too bad to make work. Granted this is a lower budget so not everything will be perfect (backyard project
I am as "pry the clutch pedal from my cold, dead toes" as they come, but even I grudgingly admit there are times I'd rather not be bothered shifting; heavy traffic, long commutes, and so on. The Maxima and its CVT was a fine companion in those situations. Awesome! Put some 20's on it too? ![]()
