Old 08-27-2012, 07:44 PM
Wikedjuggalo's Avatar
Rebuilding
Turbo Justy Project
I recently purchased a cheap 93 Justy 4WD and am in the process of modifying slightly. The engine is going to be pulled next week after I return from a business trip and rebuild! There is a bit of custom welding and piping to be done. I will keep you all posted if you are interested in seeing a silly Justy sleeper
I thought I would share some photos
The Justy
The Small 1.2L engine
(yes 3 cylinders) the engine bay has a lot of room compared to an SVX or others.
I will be using a IHI RBH5 VF4 that will be put on this bad boy. Small and lower PSI, should be a perfect choice for the small 1.2L
Feel free to post comments, suggestions and heckling.
Old 08-27-2012, 08:23 PM
Sean486 Sean486 is online now
Re: Turbo Justy Project
Sounds like a fun project. I kind of like those Justys.
Old 08-28-2012, 12:39 AM
Neat. Post some more pics, I want to see how this 3-cyl engine is set up.
Old 08-28-2012, 01:18 AM
Rebuilding
I plan to! soon as I get to rigging it up. Hopefully with in the next month it will be ready to go.
Old 09-10-2012, 12:33 PM
Rebuilding
Engine is out, now to start the fun.
Old 09-10-2012, 03:16 PM
wdb wdb is offline
dances with roads
Dang, a 9-valve engine. I'm gonna go ahead and bet there aren't too many of them in the world - at least, not in cars. Subscribed.
Does your car have the CVT? They've always fascinated me. I rented a Nissan Maxima that had one, and I thought it was way cool, but I'd really like to drive one of the Audi CVT's that do all the "lookit me, I'm pretending to be a box full of gears" tricks.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 09-10-2012, 03:23 PM
The Justy CVT's were absolute junk as were, and are, most CVT's. Early failures and complications are common. I think the concept and idea is great, but the few I've driven, drive like sh!t.
Old 09-10-2012, 04:34 PM
Rebuilding
No it is a 5spd. The CVT were notorious for failing (mostly due to poor maintenance) so a lot of them are not around. Possibly a good idea just bad timing. I am aiming for 100hp (or as close as I can get )
Old 09-10-2012, 04:48 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
This is such a bizare project. I am facinated. A great Grassroots 2013 project.
Gene
Gene and Ben
Old 09-10-2012, 05:37 PM
Rebuilding
Gene
I got the car for 700 dollars or so with the intentions of being a daily driver. Well shortly after purchase it developed a knock. I figured I'd pull it and add to it. That turbo came off a mid-late 80's subaru and is low PSI.
Old 09-11-2012, 01:34 AM
bishop bishop is offline
just in case you havent found them, http://www.dustysjustys.com/home.htm has a lot of good info and can get parts for these cute little boxes.
just realised your in keizer, hopefully ill get to come take a peak.
Old 09-11-2012, 05:37 AM
Now hook it up to that funky clutch tranny setup. Clutch less CVT
Old 09-11-2012, 06:33 AM
LetItSnow's Avatar
My 10th Subaru is a WRX
Get John on the line and subcontract a polish job on that distributor. Ha!
Neat project.
Old 09-11-2012, 08:15 PM
Rebuilding
I shall have to have John detail it, I need the engine bay to look immaculate. The piping actually looks easier then I first expected. lots of room in the front there. The exhaust manifold shouldn't be too bad to make work. Granted this is a lower budget so not everything will be perfect (backyard project )
Old 09-14-2012, 04:58 AM
wdb wdb is offline
dances with roads
I've driven two Nissan Maximas with CVTs behind their 3.7L V6. They were great! And I doubt Nissan would be selling them for so many years if there were reliability issues.
I am as "pry the clutch pedal from my cold, dead toes" as they come, but even I grudgingly admit there are times I'd rather not be bothered shifting; heavy traffic, long commutes, and so on. The Maxima and its CVT was a fine companion in those situations.
Awesome! Put some 20's on it too?
