Turbo Justy Project
3 Attachment(s)
I recently purchased a cheap 93 Justy 4WD and am in the process of modifying slightly. The engine is going to be pulled next week after I return from a business trip and rebuild! There is a bit of custom welding and piping to be done. I will keep you all posted if you are interested in seeing a silly Justy sleeper :lol::lol:
I thought I would share some photos The Justy The Small 1.2L engine (yes 3 cylinders) the engine bay has a lot of room compared to an SVX or others. I will be using a IHI RBH5 VF4 that will be put on this bad boy. Small and lower PSI, should be a perfect choice for the small 1.2L Feel free to post comments, suggestions and heckling. |
Re: Turbo Justy Project
Sounds like a fun project. I kind of like those Justys.
Neat. Post some more pics, I want to see how this 3-cyl engine is set up.
2 Attachment(s)
Engine is out, now to start the fun.
Dang, a 9-valve engine. I'm gonna go ahead and bet there aren't too many of them in the world - at least, not in cars. Subscribed.
Does your car have the CVT? They've always fascinated me. I rented a Nissan Maxima that had one, and I thought it was way cool, but I'd really like to drive one of the Audi CVT's that do all the "lookit me, I'm pretending to be a box full of gears" tricks. |
No it is a 5spd. The CVT were notorious for failing (mostly due to poor maintenance) so a lot of them are not around. Possibly a good idea just bad timing. I am aiming for 100hp (or as close as I can get :lol:)
This is such a bizare project. I am facinated. A great Grassroots 2013 project.
Gene |
just in case you havent found them, http://www.dustysjustys.com/home.htm has a lot of good info and can get parts for these cute little boxes.
just realised your in keizer, hopefully ill get to come take a peak. |
Now hook it up to that funky clutch tranny setup. Clutch less CVT :p
Get John on the line and subcontract a polish job on that distributor. Ha!
Neat project. :D |
I shall have to have John detail it, I need the engine bay to look immaculate. The piping actually looks easier then I first expected. lots of room in the front there. The exhaust manifold shouldn't be too bad to make work. Granted this is a lower budget so not everything will be perfect (backyard project :lol:)
I am as "pry the clutch pedal from my cold, dead toes" as they come, but even I grudgingly admit there are times I'd rather not be bothered shifting; heavy traffic, long commutes, and so on. The Maxima and its CVT was a fine companion in those situations. Quote:
