Old 11-04-2002, 11:40 AM
Trunk Light
Where is the mechanism located that turns off the light when you close the trunk? Mine is always on.
Old 11-04-2002, 11:53 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Trunk Light
I'm not positive, just off the top of my head, but, I think it's actually in the latch mechanism. I'll have to check, when I get home, unless someone else has the answer. (This ain't one of those "does the fridge light actually go off when you shut the door" questions, is it? )
Randy Johnson
Mike Davis -- at Reading VI
Old 11-04-2002, 12:32 PM
lee lee is offline
Open the trunk, look at the bottom part of the latch mechanism, not the part on the trunk lid.
There should be a small black plastic rectangle about 3/4" by 1/4" on the left side (as you look down at it). Pressing down on that causes my trunk light to go out.
Old 11-04-2002, 01:57 PM
Aredubjay's Avatar
Thanks, Lee. You've saved me from catching "heck" from my wife for dragging my manuals out . . . again.
Randy Johnson
Old 11-05-2002, 05:41 PM
Thanks for the info. I'll check it later. I was hoping it wasn't in the latch mechanism (like the doors are) because I manually closed that with a screwdriver and the light didn't go out.
Old 11-05-2002, 07:53 PM
lee lee is offline
Earthworm,
Maybe you've already checked it by now, but it isn't in the latch itself.
Some portion of the upper latch sticks out enough to press a switch located alongside the bottom portion. Pressed in, no light, released, light should come on. However I have no idea what would have to be ordered to make it work. I attached the wiring schematic in a pdf file since I don't know what kind of machine you use.
Hope that helps, my command of the language for descriptive diagnostics lacks a tad more than just somewhat.
