how to disable the ABS
Has anyone disabled their ABS? I just want to disable the ABS ECU and theoretically normal braking should still be functional. Just wanted to see if anyone done this before?
Thanks and please no debate about ABS functionality and all that.
If it ain't broken it, doesn't have enough features!!! '92 SVX LSL '03 4Runner '96 FZJ80 Landcruiser '90 Mercedes 300E |
Re: how to disable the ABS
Just pull the fuse. The ABS light will stay on though. I've been driving my '92 with no ABS and the light on for 8 years.
Same as above, pulled fuse, removed right from gauge cluster, didnt work after the manual swap anyway. ABS on older subarus is far more hindrance than it is help.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
Is loss of ABS a normal consequence of a manual swap? My light came on after swapping my car but I just assumed I had goofed something up and never got around to fixing it.
Ours works on our 5MT SVX. Bought converted so no clue why it works on ours.
"Peace is the flower of justice." |
Depends on the axle shafts I think, some subaru's have the tone rings on on the axle instead of on the hub so I think they may have been interfering. Doesnt matter at this point, when it did work ABS also most caused me to wreck more times than it saved me.
Thank you.
