Old 04-24-2015, 09:29 AM
Jvan Jvan is offline
MAF sensor swap question
My 94 SVX has stalling problem due to the MAF sensor. I have tried to spray clean it but problem still exists. A new one from the dealer is about $400 and ebay lists mostly re-manufactured ones for about $170. Ebay has tons of MAF sensor for Legacy's/Impreza's/Forester's for $23/$60+ and $!00+; the part #'s are almost identical to the SVX # except for the last 4 digits (SVX- AA200 and others are 2 digits/letter and digits ranging from 160 to 201). They all look the same, so are any other Subaru model MAF sensors compatible/swap for the SVX.Subaru raided the parts bin for many other part (Legacy calipers) so I'm sure that they didn't make a MAF sensor just for the limited SVX.
Old 04-24-2015, 10:10 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: MAF sensor swap question
Someone said they work just fine except for the very highest rpm/air flow. Fine for everything except maybe the track.
"Peace is the flower of justice."
Old 04-24-2015, 01:16 PM
Did you look at the "How To" for re-soldering the connections inside, it's really simple and works.
Old 04-25-2015, 12:21 AM
An EJ MAF should only be used for diagnostic. It does not measure the air properly ratioed for the SVX ecu and will run the car lean. This is bad for long term use. So, to confirm yours is bad, and someone has an EJ Subaru with a MAF, go ahead and swap to confirm. Then get a replacement.
Old 04-25-2015, 05:46 PM
No, I didn't look on how to re soldering since other Subaru MAF sensors were so inexpensive but if the other Subaru Mafs don't work, I'll have to try it. I'm not about to spend $400 for something that can be bought for other cars at a minimal cost.
Old 04-26-2015, 05:36 AM
gwynethh's Avatar
Thanx for the info Nate!
Old 05-01-2015, 03:58 PM
Searching through some old MAF threads and came across a thread swapping a N62 MAF sensor from a Z32. Is this a recommended swap for a stock engine or do I need to upgrade injectors and more?
Old 05-01-2015, 07:17 PM
You need the whole set - ecutune stage 2 chip, z32 MAF, and 370cc injectors.
Old 05-03-2015, 01:15 PM
Also, fyi. aftermarket MAFs are around $200 new for the SVX with warranty and work well.
Old 05-10-2015, 07:38 PM
elemgee elemgee is offline
I recently had a problem similar to yours - my SVX would stall when coming to a stop, or right after I accelerated from a stop. I was getting an engine code 23 which is the MAF sensor. I replaced it with one for a 97 Legacy with the 2.5 liter engine which I got from ebay for around $35. Works just fine. Only very small issue was connecting the electrical plug to the sensor was a tight fit, but thats it. Car has been running fine now for a couple of hundred miles. I just checked and there are a bunch of similar MAFs on ebay.
Old 05-10-2015, 08:10 PM
I'm very tempted to do the same thing. The new MAF sensors on ebay for other Subaru's are very reasonable but the SVX sensor is way over priced. Even $200+ for an aftermarket isn't reasonable. I'm hesitating because other posts have recommended against using the 4 cylinder sensors. Even the z62 sensor can be purchased new for under $50. I'm driving locally so a few stalls isn't so bad. For $400, I'm going to try to solder the sensor.
Old 05-10-2015, 09:16 PM
try soldering first but it that doesn't work i would run with it disconnected before paying money for the wrong part. if you disconnect it when the car is off it will run with out it. you will run rich because it will set a code and force the car into open loop but it's a lot better than running the chance of going too lean because your maf is the wrong one.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 05-11-2015, 05:20 AM
Buy the Legacy sensor and use that to get the car working. Take the SVX MAF Off and resolder it, or send it to someone to resolder it for you. When done, swap them and put the Legacy MAF on the shelf for backup.
Old 05-11-2015, 08:16 PM
You also risk burning a valve from running lean along with cat converter failures. Which only show up after prolonged running.
Old 06-10-2015, 08:47 PM
There is a need to clear this up before it becomes "Internet law".
The graph the Michael showed, has the two curves for the two Mass Air Flow units, they are very similar, slight different at full voltage readings.
The voltage rises as the air flow increases, the ECU uses this to set the fuel and the spark settings, when the voltage signal reaches maximum reading, the ECU goes to the full throttle settings that apply max fuel and spark setting, for a fully loaded engine.
The point that people are missing is that the max. voltage reading for the two units are at different air flows. The 3.3 unit reaches full voltage when it is passing 3.3 lts of air. the Legacy reaches max voltage when it passes 2.2lts. of air. So when you fit the Legacy unit to the SVX it goes into full fuel and spark settings when 2.2lts is passing, it then holds this same voltage setting while the last 1.1lts is passed.
So it won't run lean, it will actually run the same full throttle settings as the SVX unit does, only doing it 33% earlier.
Of course this will only happen at full throttle, when in open loop, at normal driving in closed loop, the Svx will use the O2 sensors to use the same settings as it does with its own MAF fitted.
