Phenolic Intake Manifold and TB spacers for the SVX/EG33 available
Big thanks to Nate for the push and help.
On the way to me are a set of gaskets, from which I will program and cut on my CNC, sets of phenolic spacers. I will make them for the manifold and the throttle body. I need to figure out a few details: Thickness Length of replacement bolts to match increased thicknesses Which exact grade of phenolic to use Any comments, suggestions, discussion before I get too far down the rabbit hole?
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com |
Re: Coming soon: phenolic spacers for the SVX/EG33
Great to hear... but what are the costs looking like?
Re: Phenolic Intake Manifold and TB spacers for the SVX/EG33 coming soon
I think costs will be reasonably in line with those for other cars.
I plan on selling a complete package of the spacers, gaskets, and longer bolts as required.
The upper ones are easier to make and install, the lower ones have more of a heat-limiting effect. I see no heat-related reason for the throttle body spacer. Once the spacers are installed knock sensors and under manifole hoses are easier to get to and the intake temperature drops ALOT! Some of us are anal/thorough, and are particular about the bolts we install. I have a bunch of pictures in my locker from Chi'kes phenolic body install. I think this should help. Tomhttp://www.subaru-svx.net/photos/use...svxfiles|24784
1992 Dark Teal LS-L 237k #103994 (Sold) GC8 Nardi Steering Wheel/ Crossed Drilled Rotors/ 18" Exel Evo Wheels/15min Mod/ 6k HIDs/ECU Crush Mod/ Power Mode Mod 1997 Brilliant Red LSI 151k #100109 PWR AU Radiator, Stebro Catback, Hella Supertones, SS Brake Lines, Cross Drilled Rotors, QC, Power Mode Mod, SSR GT3 Wheels 18x8 et35 1997 Ebony Mica LSi 177k #100321 |
About 2 weeks later I got an email stating that they use Phenolic G10 GRE (Glass Reinforced epoxy). "G10 phenolic is mechanically stronger and provides the best in thermal transfer resistance translating into lower temps and more power." I looked into it and this stuff can maintain a safe environment up to 500*F, can handle race fuels, E85 and methanol. The two thicknesses Grimmspeed carries are 3mm = .118 inches & 8mm =.314 inches. Obviously thicker means better cooling and greater volume of air in the intake manifold. Just like svxfiles mentioned below, the Outlaw Engineering ones were .333 inches = 8.4mm. Cooling should be about 20-40*F depending on ambient temps. As to the "Length of replacement bolts to match increased thickness" question. The NEW bolts need to be 5mm longer than the stock ones. Also, the cost for Outlaw Engineering spacers was $105 and that included the intake manifold & throttle body spacers, shipping, gaskets, hardware and stickers for 20+ AWHP ![]() I think somewhere around $115-$130 shipped would be reasonable for the intake manifold and throttle body spacers! You have a happy customer here (SVX oil cap) and can't wait to do business again (Spacers).
Sam Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners My Locker Last edited by Svx95; 11-01-2014 at 07:53 PM. Reason: Adressed replacement bolts |
I will be anxiously awaiting there availability
1995 POLO LSI 76K MILES SOLD Last edited by SVX92-97; 11-01-2014 at 11:11 PM. Reason: edit |
I'm gonna need a set of these eventually too.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
Just my $0.02:
I looked into having these made here in town and the biggest thing I ran into was the difficulty involved with milling the phenolic material. Most traditional CNC machines won't tolerate much work on the stuff because it is so abrasive. It'll wear out your tool very quickly. The other problem is that the dust is carcinogenic! The one place I can source the material locally has to shut down their shop, clean everything, cut the material, and clean everything again before they can resume the work. I'm not sure what kind of a CNC setup you have but I hope it can tolerate this kind of material. A water jet will be your best bet if you have access. Additionally, the G10 GRE that Svx95 mentioned also goes by the name of "FR-4" and "FR-5". They aren't quite the same stuff but almost identical in terms of performance to G10 (the "FR" stands for Fire Retardant). FR-5 has a higher temperature tolerance than FR-4 but both will work for normal applications. You might be able to keep costs down by using FR-4 instead of FR-5 for stock applications; my local supplier wanted substantially more for 5 than 4. Do you need CAD files of the gasket cutouts or have you already made those?
1996 SVX LSi : Work in progress, future garage queen 2013 Acura TSX: Mistake |
Yes..it is nasty stuff to work with, I have worked with G10 before in previous jobs building composite stuff.
I have some gaskets on order, but if you or anyone else has files, I would love to have them so I don't have to make them myself. Hope to be cutting the first set within a couple weeks....
Happy to help with that. Any chance we can work out a deal for the assistance?
Something will be arranged
![]() Did you make those files yourself? Just curious to their origin.. Thanks!
Whoop!
The file is programmed and ready for the mill. Also..my OEM gaskets shipped today. I plan to head to the shop tomorrow and mill a sample out of some plastic sheet I have, just to check the dimensions, etc. and make sure all is well. If good, then it's time to order some material and make some dust. (and a price list) What are the group thoughts? I can supply these with or without gaskets, I could use Subaru gaskets or aftermarket, many options... I will include the longer bolts in any kit option.
I only like Subaru for the intake manifold gaskets.
Not cheap but very good sealing. What thickness are you going with? Tom
Would you be willing to make a one off set of 1/2-3/4 inch thick spacers that would go between the intake manifold and the injector stacks?
Thanks Bill
