Old 08-23-2013, 12:53 AM
Traitor_Moron's Avatar
Traitor_Moron Traitor_Moron is offline
BoreD'oh Poseur Faux Pas
Rejoining the flock
I just purchased my 4th SVX ... a lovely 1996 Bordeaux LSi with 122k mi. She needs a bit of care but nothing too dramatic. I am having an odd coolant issue I could use some advice on, if someone is willing. I will supply details if anyone replies. Enjoy the pics below
Jeremy
1994 Subaru SVX LSi - Laguna Blue Pearl - sold
1994 Subaru SVX LSi - Emerald Green Pearl - sold
1996 Subaru SVX LSi - Bordeaux Pearl - traded
1996 Subaru SVX LSi - Bordeaux Pearl - sold
1994 Nissan 300zx Convertible - Emerald - 102k mi
1999 Mercedes SLK230 Sport - Brilliant Silver - 83k mi
1990 Ford Taurus SHO - Oxford White - 10k mi
Old 08-23-2013, 02:39 AM
Re: Rejoining the flock
WOW.
I have never heard of an SVX with a cooling issue!
So, what is She doing?
Old 08-23-2013, 03:24 AM
Sarcasm Noted..the only coolant related problem I've ever had with my previous SVXs was radiator replacement.. this one is new.. it seems to trap all the coolant in the overflow.. i replaced the cap and hoses... next is the thermostat.. and pressure check
Jeremy
Old 08-23-2013, 05:55 AM
This one is NOT new, but I don't want to be the first to say it without more info.
The coolant reservoir continues to fill up and not go back down?
Could be as simple as a clogged overflow bottle which would let the radiator pump fluid into the reservoir, but not let it return to the radiator when cold.
How is your temperature gauge acting? Especially at lower RPMs and MPH after driving at highway speeds for a while.
Old 08-23-2013, 08:29 AM
May as well just come out and say it, John.
Old 08-23-2013, 11:21 AM
Some of the information that would help in any coolant issue is;
Is the car overheating?
Are both of the electric radiator fans working?
Is the top radiator too hot to keep your hand on?
Is the bottom radiator hose cold when the top hose is hot?
When you squeese the upper rad hose when the engine is cold,
does the coolant rush into the over flow?
Old 08-23-2013, 12:32 PM
I am sorry.. let me clarify.. when i said "new" i meant new to me... hence my asking the forum, in their infinite wisdom, for guidance and insight. If i needed to be berated for asking a question i'd check with my local Pepboys mechanic. As far as the behavior ... it air locks the radiator.. the coolant gets warm, it expands in volume, flows into the overflow tank, and stays there. i have replaced the radiator cap in a quick futile effort to possibly resolve. when it traps the coolant the rad cap is cool to the touch and can be opened, i allow the coolant to then flow back into the radiator and all is well for a period of time until it decides to do it again. on a road trip (had to get home) it lasted 300ish miles before needing to stop for gas and allowing the coolant to flow back into the radiator. the radiator and hoses are new, the 120k mi service was just performed. and yes the fans are working as they should.
Jeremy
Old 08-23-2013, 09:28 PM
I have nothing to add but a suggestion to change your username, Moron.
And why does your signature look better than mine?
Old 08-23-2013, 09:39 PM
I am more intrigued with his vanity plate.
Something similar to "ASSBNDT" ?
Old 08-23-2013, 09:48 PM
I am more curious with his vanity plate.
Fixed it.
Old 08-23-2013, 10:04 PM
Yes 123456
Old 08-24-2013, 07:27 PM
yeah the name sucks but i cant change it.. and Nevada wouldnt let me renew the plate.. im open to suggestions.. anyone know what causes the coolant issue??? also can the rear bearings be repaired/replaced or is it cheaper to do the entire hub??.. will a FWD hub assembly work? theres a laguna fwd in my local pick a part if anyone needs parts..
Jeremy
Old 08-24-2013, 08:51 PM
redlightningsvx's Avatar
Collision Refinishing Tech
pressure test the cap and see if it is reading proper lbs which I think is 13? I've had several BAD caps in a row from subaru.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-25-2013, 01:36 AM
tried another new cap today.. same issue persists.. though i can drive for an extended period around town without issue.. im leaning toward replacing the thermostat? any thoughts.. and the bearings? is entire hub replacement easier?
Jeremy
Old 08-25-2013, 06:59 AM
"yes the fans are working as they should"
