Old 06-19-2013, 05:30 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Rear glass antenna attachment wire (was "Defroster wire")
So as I was removing the headliner I found that the upper defroster wire was completely disconnected. I never noticed because it was tucked above the headliner.
How do in repair this? I currently have it wrapped in electrical tape in case I need to use the defroster. Do I simply solder it back up there to where it was before?
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 06-19-2013, 07:23 AM
Re: Defroster wire
How does one solder upward?
http://www.thinkgeek.com/product/b70c/
Old 06-19-2013, 08:36 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Defroster wire
You will need to put solder on the wire and try to transfer solder from the soldering iron tip onto the contacts. Once you have both sides with some solder hold both pieces together and apply heat. If you have enough solder on both pieces they should bond together.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 06-19-2013, 05:11 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: Defroster wire
place something like wodden board under soldering area - you don't want solder melting anything if it "drips" off.....
As for the carbon "solder-less" glue I would worry about what sort of voltage drop/heating of contact you will get when you turn on the unit???
Try to find a silver or copper loaded carbon glue - less resistance = less volt drop = less heat across joint. (you could try mixing this yourself?).
Asahi Chemical company makes various types like this for electronics industry....I have used them in a previous company for making tracks on plastic printed circuit boards.
(you could ask for a sample pot).
Old 06-20-2013, 01:23 AM
davew833 davew833 is offline
Re: Defroster wire
Just so you know, that's not a defroster wire, there's actually an FM antenna grid in the top portion of the rear window and that's where that wire goes. Mine came off too and I think I re-soldered it without too much trouble.
davew833@yahoo.com
Former 6-time SVX owner
Old 06-20-2013, 01:31 AM
Re: Defroster wire
I used the exact stuff that I linked, it works fine. If there's a voltage drop, it still works plenty well. But, yea, for something that requires precise voltage or whatever, I would use something better. I couldn't figure out a safe way to solder it myself, but the wire glue was pretty easy.
Old 06-20-2013, 09:41 AM
B 4 You's Avatar
#lolsvx
Re: Defroster wire
That makes perfect sense. It totally skipped my mind that we have an antennae back there. My radio signal sucks (like I ever use it). I'll try using that glue stuff.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 06-20-2013, 02:15 PM
SURTEESS's Avatar
Re: Defroster wire
Yes the antenna wire should be fine with carbon compound - for higher currents you would need to use different type of material, something like this -
http://www.flex007.com/pages/zone.cgi?a=92775
Old 06-20-2013, 06:05 PM
theflystyle's Avatar
Re: Defroster wire
So did certain models come with the antenna in the glass?
1994 SVX LSi
2008 Legacy 3.0R
Old 06-21-2013, 06:59 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Re: Defroster wire
I believe all models use diversity antennas, one in the glass and one externally.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
