Old 02-10-2013, 12:49 PM
bishop bishop is offline
anybody change their steering wheel?
As much as i like the interior of the svx the big grey marshmallow in front of me just doesnt seem to match the rest of it. Has anybody changed their steering wheel to anything else?
Old 02-10-2013, 01:04 PM
Re: anybody change their steering wheel?
Lot of people put in the Momo wheel from the WRX. It is a huge upgrade in the looks department, however you lose the airbag.
Old 02-10-2013, 01:36 PM
scoobymal's Avatar
scoobymal scoobymal is offline
I fitted an STI version 8 wheel to mine, I lost the airbag but kept the cruise control .....
Old 02-10-2013, 02:35 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
How do you lose the airbag & still able to get compliance at testing stations ?
Old 02-10-2013, 02:39 PM
I don't believe the airbag system is checked in any state in the US. Very few states have actual inspections as it is and I don't believe any test/chek the airbag system. As long as the airbags are in place (even if different steering wheel) that is all that matters.
Old 02-10-2013, 03:30 PM
steveherman steveherman is offline
Icing did a momo swap and kept the airbag and the cruise.
Old 02-10-2013, 04:02 PM
Are you quite sure about that, my understanding was that they used different voltages.
Old 02-10-2013, 07:22 PM
I used the SVX airbag charge from the stock steering wheel. (NOT responsible if something blows up in anyone's face). The wheel is a 90s Legacy GT wheel (pics in album linked in sig somewhere), and I think I had to trim the inside just a little bit to make the airbag charge fit, since it's a little bit bigger than the one that was in there. Also made sure the body of the airbag charge wasn't grounded to anything, since neither were when I got them. Making the horn work was pretty easy, and obvious once both wheels are opened up in front of you. As for the cruise, the place to mount the switch was already there, just had to cut a hole for the switch to poke out through in the back panel of the steering wheel. I did have to cut a wider hole on the back of the steering wheel where it mounts to the column to fit the wires through it, and because there was a round part that rubbed against the SVX column trim.
I picked a 90s legacy wheel since I figured the airbags themselves would be as similar as you could hope for. The airbag charge and the bag itself are from different cars, so there's no way to know for sure whether they will work perfectly together without blowing one up to try it out. I hope never to find out. The newer WRX wheels are smaller in the middle section, so I don't know if I would make the same assumption with those that they'd be close enough to work.
There are some MOMO outback wheels that are black with woodgrain on the top and bottom of the wheel itself, that look like it would match the inside of a later, lighter woodgrain SVX pretty well.
AGAIN, I AM NOT RESPONSIBLE IF YOU BLOW ANYTHING UP.
Old 02-10-2013, 07:43 PM
Yes. I am quite sure.
Old 02-10-2013, 07:45 PM
Old 02-10-2013, 07:53 PM
Both our 2002 3.0 H6 VDC Outback sedan and wagon had the wood and perforated leather wheel. Some of the L.L. Bean models got the same wheel, but with MOMO in the center.
Old 02-10-2013, 08:50 PM
that is sexy, though with it so glossy i would have to pull out all my "wood" trim pieces and clear coat them to match.
Old 02-10-2013, 10:00 PM
Far much easier to get some #0000 steel wool and take down the gloss on the wheel to more of a satin finish to match the dash.
Old 02-10-2013, 10:20 PM
Ah, that explains why I couldn't find any examples on ebay. Thought they all had the "MOMO". I quite like my all black one. Maybe one day I'll get a woodgrain one for my 97. I worry how well the black will match the rest of the tan interior though. What do you think, having seen both in person?
Old 02-11-2013, 06:05 PM
zaueugen's Avatar
zaueugen zaueugen is offline
So besides the woodgrain and the center name, the rest of the wheel's size and shape is exactly same ? Because I would like an all black wheel with subaru in the middle not momo
