Double the Joy
I recently came across a shop selling Strong Arm products locally.
Since shipping from the US is not always a viable option, I had to "improvise" with what is available. They don't have the SVX struts in stock. They simply bought a "shipment" of Strong Arm from the US and are selling it in pieces in my country. They are not even dealers for it. Anyways, since my future project involves adding a [top secret] wing project which will add a few pounds here and there, I thought to fab something more durable for my car. After 80 hours in trial and error, I made it! It works perfectly for my need ![]() ![]() ![]()
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() Last edited by SilverSpear; 10-19-2012 at 04:35 AM. |
Re: Double the Joy
Nice job Danny! What happens when you hit the release on the stock trunk with the struts doubled up like that? Does it pop up like a speed-brake?
![]() Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
Re: Double the Joy
Unfortunately no. The trunk hinge system of the SVX does not allow the trunk to pop up as you think. But once it is half way, you simply.... cannot hold it from opening all the way ![]()
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
Re: Double the Joy
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
Re: Double the Joy
Re: Double the Joy
Seems like they open more smoothly than mine (the ebay lift support depot ones).
Re: Double the Joy
Care to share your design for the brackets (I'm assuming you made them yourself), and the specs on the struts? I may copy you if you don't mind
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
Re: Double the Joy
I don't mind sharing the measurements, but as a note you will need:
- grinder with cutting and grinding discs; - welding machine; - 13mm bolts, nuts, washers, locks; - impact drill or drill bench; - bench holding unit (whatshamacallit); - 4mm iron plates; - paint; - some skills... Just gimme some time, I am still testing the entire system. I might even make it better...
Re: Double the Joy
And I have done a bit of fabrication before ![]()
Re: Double the Joy
http://www.lstechnologies.ca/recharging.html I know a few Ferrari guys who have rebuilt their Boxer engine cover struts using this company. |
Re: Double the Joy
why would a double strut be necessary, how often do you open your trunk, that a single strut wouldnt be sufficient
1995 POLO LSI 76K MILES SOLD |
Re: Double the Joy
He's fabricating a new fiberglass rear spoiler, which will add a few lbs to the trunk lid. The stock single struts are barely enough to lift the factory lid and wing. Let alone an additional 7 lbs or so. |
Re: Double the Joy
I think a stronger recharge on a rebuilt set of single struts would suffice.
Re: Double the Joy
Close... I will be repositioning/lowering my current wing and adding a mechanism inside the trunk lid...
Re: Double the Joy
Hehe. Not so Top Secret now
