Old 07-28-2012, 06:02 PM
bazza bazza is offline
EG33 engine build with pics
Old 07-28-2012, 06:03 PM
Re: EG33 engine build with pics
Old 07-29-2012, 08:08 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Bazza,
How did you check out the crank before installing it? Cracks? Size of mains? In/Out of round of mains?
Thanks.
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-29-2012, 10:11 PM
Old 07-29-2012, 11:12 PM
torxxx torxxx is offline
looks interesting. I've thought about doing that with my EG33. 197k miles on it, I'd like to see it run for another 100k..
How much $ you got into that shortblock? Just a rough estimate works, I just want to know what I could be getting myself into.
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car
86 Lifted GL wagon well over 600k miles on the chassis
98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires
Old 07-30-2012, 06:47 AM
Rods, bearings and head gaskets are probably around $1K thus far.
Old 08-13-2012, 05:42 AM
Old 08-13-2012, 08:00 AM
'E''s Avatar
'E' 'E' is offline
nooooice bazza
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 08-13-2012, 08:33 AM
SVXRide's Avatar
Originally Posted by bazza View Post
Got a bit distracted over the last week hehehe
Bit more build progress over the weekend. Couple of pics of the new headers and the baffled sump setup that I plan to test before the dry sump goes in - the pickup also extended by a coupe of inches and oil temp sensor installed into sump.
Bazza
Looks great! What size pipe are you using for the headers? SS?
Any need to add a diagonal brace to the extended pickup?
Bill
Old 08-14-2012, 01:58 AM
Originally Posted by SVXRide View Post
Bazza
Bill
2.25" coming off each cast header then merging down a 3" collector. Then tapers down again at the turbo entry via 2.5" then 2.25" (in about 1" distance) for the Garret T3 flange.
Using mild steel because it's cheaper haha. Stainless is weaker at high temperatures and would prolly crack (like last time) so prolly a good thing.
I don't think a brace is required - the stock pickup is very strong and TIG welding tends to make nice strong welds so should be fine.
Old 08-14-2012, 07:44 AM
Any other changes needed to make the extended oil pickup work? If not then I'll probably do that as well.
Noticed you flipped the headers forward, you just swap them side to side and they bolt right on, right? That's how they look to me, just want to confirm.
Old 08-14-2012, 07:51 AM
SVXRide's Avatar
Bazza,
Thanks for the feedback! I only asked about the pickup because I've seen folks do that on the STI 4 cylinders when they've extended the pickup.
Good point on the mild steel!
Bill
Old 08-14-2012, 10:41 AM
neverLift neverLift is offline
You mentioned moving the engine down and back, what all was required to accomplish this? Any photos? I assume different engine/tranny mounts, shorter driveshaft as well?
cheers
-Evan
Old 08-14-2012, 04:52 PM
dynomatt dynomatt is offline
Evan, it's mounted in a GC8 in case you weren't aware.
Old 08-14-2012, 05:05 PM
Yes, it looks as though I may have misinterpreted his statement. Bazza, do you mean "downwards and rearwards" relative to the EG33 position in the SVX?
I am also putting a EG33 in an older Impreza, so if he had changed the positioning when he installed it in the Impreza chassis, I was curious how he accomplished it. I have thought about doing it, but I always get stuck on the angle of the front axles becomes very steep and presents a potential problem for the CV joints. Possible, but very expensive, more than just fabricating new engine mounts.
cheers
-Evan
