opinions/ ideas about modifying stock struts to be stiffer
my dad is experimenting with putting thicker oil in the spare set of struts i have
![]() so far he has drilled a hole in the bottom of the shock and i think he plans to put one in the side too , he told me there was only about 300 ml of fluid in the one he drilled and that it was very thin fluid so he is going to see how it reacts with some trans fluid and if that doesnt do much he will try a thicker fluid his plan to re-seal them is to weld a nut over the hole so a bolt can be used to seal it back up once he gets one done and it seams like it works well he will do the other 3 and we will install them and see how they feel i will get a few pictures to show what it looks like/ how it was done ![]() |
Re: opinions/ ideas about modifying stock struts to be stiffer
Struts are not filled only with oil though. AFAIK, they are filled with a pressurized oil/air emulsion. So, I don't know how well that will work.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
The gas is nitrogen, I believe. Very low pressure on the SVX strut. The idea is to try to prevent cavitation at high speed displacement.
Be very careful you drill only thru the outer tube ![]() Mine had a little over 250ml of fluid - very thin indeed. If you experiment with several fluids you might want to try the ones intended for bike forks. Make sure you bleed the strut like this (must be off the car): http://www.subaru-svx.net/forum/showthread.php?t=60066 Tapani |
![]() dad said he didnt notice any air being expelled from the strut when he drilled through the bottom of it i mentioned bike fork fluid and he said trans and bike fork fluid have a very similar viscosity i told him about the bleeding thing and he said yeah he knows haha ![]() he just bought some stuff (nuts/bolts/nipples i dont actually know what hes doing with that part yet ) to bung it back up with but he thinks that the idea should work well if not really well ![]() he told me what he is doing is basically what the rally guys used to do back in the older rally days (although they would have had servicable struts that didnt need to be drilled to replace with thicker fluid ![]() |
![]() The fluid to use is the bike fork oil as you can get a range of viscosities. To check what the original oil is, use a sheet of glass at an angle to run a drop of oil down, and compare with a known fork oil. Harvey.
yeah , he is just seeing how it acts with the trans fluid , il have to tell him that trick (although he probably knows it ![]() |
The August issue of Grassroots Motorsports has a related article which may be of interest. I also have a pdf file I can e-mail.
Gene [IMG] ![]() [IMG] ![]() [IMG] ![]()
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
thanks for the input ![]() its a lot easier to do this with struts that can actually pulled apart though ![]() he has been a mechanic since the late 70's - early 80's i think he did it to one of his old cars back before i was born (he had one particular ute (truck) for about 25 years ) ![]() |
