Remote
I got my car back from repair shop. Now when I go to remote lock the car, instead on on beep to lock and 2 to un lock it does about 5 real fast beeps and locks the doors . Press again and it beeps 5 short fast beeps and the door unlocks . What up with this ? What did they do to my alarm?
Re: Remote
When the security system is disarmed with this switch, the locks still work, but the system emits a rapid system of beeps to let you know the alarm is disabled. Without the key in the ignition, the LED on the security button should blink about every 1/4 second. Once you arm it with the remote, it blinks a lot slower (about every 5 seconds or so)
Re: Remote
Only working in one position. The dash light blinks and I get rapid pulse horn when I try to arm it and the doors do lock... I push the dash button the light goes out and no auto lock or remote alarm noise .Could something be open? I only have 2doors and a trunk. The hood doesn't matter? Could they have messed it up when they checked the CEL under the kick pad? They almost ripped my dash side panel off ( area of the switch )
Re: Remote
Fixed it , clock and dome light were not working also. I replaced the fuse under the hood and it works now . Go figure
Re: Remote
Getting tires next week, taping a note to the steering wheel just because..G
I thimk ther4 I an, what? huh! 03 Baja. 05 Baja turbo 92legacywagon"snow" 94legacywagon"whinny" 84Brat"huey" 92svx"samantha".pearl 92svx"sabastian"4.44 silver 92svx"sabrina".ebony 05legacy gt limited "Moon" blue. 06 Subaru legacy gt limited. |
Re: Remote
Yep. Best thing I've ever done for mine are to do everything myself that I can and annoy the hell out of the mechanics when I have to take it in. (I'm currently exploring the feasibility of installing a lift in a home garage :P.)
Re: Remote
I asked them it they ever worked on an SVX .. Answer we work on everything.
