Old 04-15-2012, 09:40 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Camber question
My tires have excessive wear on the inside of them. Im positive it was because of a bad alignment job.
This is not my car, but my tires look just like that. They're loud too because of it. I was wondering, since I just need these to last me until the end of the summer, could I have an alignment shop camber them outwardly ever-so-slightly so that the inner edge theoretically wouldn't be touching the pavement? Would this cause any problems? I know it will damage the tires' outer edge, but I don't care since I don't plan on using them much longer. Just wanted to ask someone who knows more than me (and the shops that will truthfully lie to get a few bucks). I don't feel like getting a blow out, and I need to drive halfway across pennsylvania twice before the end of the month. Thanks for the input
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 04-15-2012, 11:01 PM
Green1995SVX's Avatar
Re: Camber question
That would not be a good idea. It's time for new tires, especially if you plan on doing a lot of driving.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-15-2012, 11:38 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Re: Camber question
This. Positive Camber is dangerous, and looks absolutely retarded.
Old 04-15-2012, 11:57 PM
Re: Camber question
This is true, on both counts. You would be better off having the two tires swapped from side to side, and leaving the camber alone. But if you're going to do that, might as well just get new tires and have them put on.
Chuck, is that really bad camber, or is that car messed up? There's no way they could have gotten the camber so positive through normal means. Damn.
Old 04-16-2012, 04:34 AM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Re: Camber question
Just run lots of air in them.
That will keep the edges from touching as well.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 04-16-2012, 06:14 AM
Mr. Pockets's Avatar
Moderator
Re: Camber question
From my experience using tire-destroying camber on my RX-8 for autocrossing, I can tell you that toe does way more to shred tires than camber does.
Also, please don't try to use weird alignment specs to offset the wear on your tires. If you really could get that much positive camber out of the car, it would have a terrible effect on your ability to steer and brake.
If your tires look like that, you need new tires and an alignment.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-16-2012, 08:32 AM
dcarrb dcarrb is offline
Re: Camber question
Maybe it's something to do with how I drive, or the curvy roads I frequent, but that looks very much like my typical wear pattern dating back to the bias-ply days, even with routine alignments and rotation and slightly higher-than-spec air pressure. As suggested above, just confirm proper alignment and buy new tires.
dcb
Old 04-16-2012, 12:11 PM
B 4 You's Avatar
#lolsvx
Re: Camber question
Good to hear. I think I'm gonna pick up a used set that'll last me a few months. Thanks guys :]
Edit: Actually, if anyone has a decent set of stock size tires they'd be willing to sell and ship me, send me a PM.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-16-2012, 12:30 PM
Moderator
Re: Camber question
Having a set of used tires shipped only to use them for a few months before you have to replace them again sounds only marginally cheaper than just buying a new set on Tire Rack. The Ecsta AST is $76. I have a set on my RX8 and, while certainly not fantastic, they're positively 'acceptable.'
2005 Outback
END OF LINE
Old 04-16-2012, 01:29 PM
B 4 You's Avatar
#lolsvx
Re: Camber question
Right, but I plan on using these rims for winter and my new ones for the summer months. I don't want to buy nice winter tires and use them for the rest of the summer either...
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 04-16-2012, 03:21 PM
SVX8588's Avatar
Re: Camber question
Cool ones I hope!
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 04-16-2012, 08:44 PM
B 4 You's Avatar
#lolsvx
Re: Camber question
Originally Posted by SVX8588 View Post
Cool ones I hope!
There's one problem. I don't have them yet. I plan on getting a nice set of gold sti bbs's. If I don't like the gold (which I'm sure I will) I'll powdercoat them gunmetal black. I'll take whatever color I can find. Anything will be better than the current ones I have.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
