Old 02-06-2012, 11:57 AM
Wikedjuggalo's Avatar
Rebuilding
Brittle hoses under Intake manifold
So, this all started when I wanted to replace the PCV valve for a variety of reasons. Removing the hose that goes off the top left side of the throttle body that goes under the black cover of PCV valve.
See Picture here
I had to remove the intake manifold at that rate, if it was so brittle it snapped off. That was fun, but I finally got it off and removed
See here
And Here
But back to why I posted this. What else should I replace while I have the intake manifold off? At this rate taking time to order parts and what not doesn't really matter, rather have it working right then rush and have to do this again.
Should I order the hoses from Subaru or replace them with regular vacuum lines? If you look closely in the picture you can see pretty much every hose has cracked.
Old 02-06-2012, 12:06 PM
kwren's Avatar
kwren kwren is offline
Re: Brittle hoses under Intake manifold
I personally would get them from Subaru if possible.
Keith
Old 02-06-2012, 12:30 PM
dcarrb dcarrb is offline
I'd replace every inch of rubber hose under there. If you've never replaced knock sensors, now would probably be a good time to do that, too. There's no reason not to use generic cut-to-fit hose wherever you can.
dcb
Old 02-06-2012, 12:56 PM
flamestone's Avatar
flamestone flamestone is offline
dcb
Agreed.
And check that little valve that runs inline with the thin vacuum hose that runs to the black plastic tank you can see at the bottom of the photo of the manifold upside down. Make sure it's not cracked.
Old 02-06-2012, 06:08 PM
Rebuilding
So far all the smaller lines I got from a local parts store. The bigger ones how ever, they did not have and I don't know if I feel comfortable using Heater hose but could. What is going to kill me is the part listed as "Valve assembly-duty solenoid" 16102AA020 which is what broke. Its listed at over 130 dollars. I will be calling about that tomorrow.
Old 02-06-2012, 06:46 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Did you break the nipples off?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-06-2012, 07:09 PM
Rebuilding
Yes the nipples broke off while attempting to remove the hose.
Old 02-06-2012, 07:36 PM
Mychailo did a write-up on this back in 2005.http://www.subaru-svx.net/photos/files/How-To/30340.pdf
I always use heavy duty vacuum line because its alot more durable, and about 1/5th the cost.
Unless its for a customer who wants stock Subatu parts for five times the price........
BTW, the excessive use of rolleyes is to indicate sarcasm!
Old 02-06-2012, 07:47 PM
I've fixed similar vacuum fittings with various plastic tubes (pen barrels...) and some epoxy.
Old 02-06-2012, 07:57 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Im sure this is the area where my idle problems are coming from. Once I get the time, I will take a look. OT, I wish you had a trailer and could come pick up my car
1995 POLO LSI 76K MILES SOLD
Old 02-06-2012, 08:38 PM
I have a trailer but for me to come there is not that practical..
However, I have an idea...
PM or phone call to follow.
Old 02-06-2012, 08:47 PM
Rebuilding
Taking off the manifold isn't hard. Now putting it back...
Old 02-06-2012, 08:49 PM
Rebuilding
What size are the larger ones that go into the snorkel?
Old 02-06-2012, 08:53 PM
What size are the larger ones that go into the snorkus?
Phone broke?
Do you mean the 1/2" inside diameter ones for the PCV and the IAC?
I have no idea.
Old 02-06-2012, 08:56 PM
Rebuilding
Phone broke?
I have no idea.
No.. isn't it past your bed time :P?
