Old 12-09-2011, 01:50 PM
SubaruJawn's Avatar
SubaruJawn SubaruJawn is offline
got my SVX 12-8-11
Vaxine: 1992 SVX
hey guys
like i do on other forums, i start a thread specifically about my car.
Vaxine Alcyone
First off some info
1992 LSL AWD 4 Speed Auto
Old 12-09-2011, 01:51 PM
SubaruJawn's Avatar
got my SVX 12-8-11
Re: Vexine: 1992 SVX
Issue 1
Power Steering Pump Leakage.
Old 12-09-2011, 02:04 PM
Green1995SVX's Avatar
Your o ring is leaking, but judging by the fact that you told me you're losing all of the fluid in less than a day, you're leaking fluid elsewhere. Check the cooler to make sure it isn't rusted through. Also check the rubber part of the high pressure line near the rack.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 12-09-2011, 02:05 PM
http://www.subaru-svx.net/forum/showthread.php?t=54237
Old 12-09-2011, 02:07 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
I remember mine looking a little like that... I had to remove the hose for more room to access the timing belt and the thing was completely dry rotted and ended up just ripping off like tearing a wet piece of cardboard. Probably wouldn't hurt to have it replaced.
1994 subaru svx le 112k
Old 12-09-2011, 02:48 PM
Don't forget to register it on Earl's list of 92's
Old 12-09-2011, 03:26 PM
Is it landing on the ground? Mine developed a pin hole in one of the lines going to the steering rack . I ended up replacing all of them PITA. They range from $125 to only $35.00 there are 4 or 5 . If I had to do it again I would have them made. Try the O ring trick first . The Tank all pealing means to me this has been a long running problem, Spilled fluid refilling caused that . Make sure you don't use any Power steering fluid . ONLY autoMatic Tranny fluid .
Pictures of the inside and the pass side please .
Old 12-09-2011, 08:34 PM
Put on the mittens , get out there and clean that car, get some pictures , You are an SVX owner now butch up <LOL> ,I got my snow tires on and my new generator , I am ready for the snow on the 17th of DEC. R U?
BTW here is a ride in my SVX
http://www.youtube.com/user/elmer338.../2/l13s-Gs16gQ
Old 12-09-2011, 08:45 PM
SubaruJawn's Avatar
got my SVX 12-8-11
thanks to GreenSVX aka Mike
we figured out its the Cooler, the fluid is along the rad support and down the side of the rad itself.
i lose allot of fluid, short distance and the pump will cry again.
i will get brake cleaner to clean up all the old fluid once i get the replacement cooler.
did that already.
Old 12-09-2011, 08:53 PM
SubaruJawn's Avatar
got my SVX 12-8-11
Pictures of Vexine.
this is after she got a shower:
i'll get interior pics tomorrow.
Old 12-10-2011, 05:46 AM
You said the power steering was leaking now you say the cooler is leaking. So your loosing 6 0z of tranny fluid out of the power steering reservoir tank a day and it is the cooler.
I know it is cold out but is the A/C working ?
Old 12-10-2011, 07:53 AM
SubaruJawn's Avatar
got my SVX 12-8-11
the power steering's cooler.
the a/c did work when i test drove it.
he said it was converted over, but cant remember the type he said.
i'm not leaking tranny fluid, just power steering.
Old 12-10-2011, 08:15 AM
When conn says your leaking tranny fluid, that's what he ment.
SVX doesn't have power steering fluid, It uses ATF.
Old 12-10-2011, 09:22 AM
SubaruJawn's Avatar
got my SVX 12-8-11
oh shyt ! i been putting powersteering fluid in !
to late to put ATF in ?
Old 12-10-2011, 09:26 AM
Out of curiosity, have you been using ATF in your other Subie's power steering systems?
-I realize the XT6's have the electronic power steering
