Old 11-06-2011, 04:13 PM
whtrabbitjoe77 whtrabbitjoe77 is offline
Alternator Plug
After replacing my knock sensors I noticed the plug and wires on my alternator are toast. where can I get a new plug with a pig tail on it other then the dealer?
1997 Polo Green LSi #352 163,000 miles, let the rebuild begin!
Old 11-06-2011, 06:59 PM
Re: Alternator Plug
"00 PM
Pristine Green Polo Machine
Re: Whan Can I get A New Alternator Plug
Originally Posted by Hocrest
I think John "svxcess" found a source for these? If he doesn't reply here send him a PM.
It used to be Northwest Regulator Supply. They only deal with manufacturers now.
But you can buy them directly from their distributor Electric Motor Service in Logan, WV. Their phone number is 800- 697-6070
The part number is 050-012252 and they go for $9.53 each plus shipping with no minimum. I already ordered two more."
Old 11-10-2011, 03:43 PM
Re: Alternator Plug
Thank you, i will call them tomorrow
Old 04-09-2013, 12:50 AM
kjoyes kjoyes is offline
Re: Alternator Plug
Hijacking this thread
I de-pined my Alternator plug to repair It
I dont know, if i got the wire switched so would someone tell me when looking down at ur alternator plug wire is the white wire on top or the bottom? thanks
Old 04-12-2013, 05:04 PM
kwren's Avatar
kwren kwren is offline
Re: Alternator Plug
Just another great example of how an SVX is like a pistol... One is none...
With 2 you could simply open the4 hood on the other one and take a look!
Keith
Old 04-12-2013, 09:16 PM
Re: Alternator Plug
On all of my SVXi both wires are white.
However the thick wire goes toward the passenger side of the SVX
(in America) and the thin wire is more to the top.
Old 04-12-2013, 09:44 PM
Re: Alternator Plug
THIS SHOULD HELP.
Old 04-13-2013, 05:40 PM
Re: Alternator Plug
that looks just like mine, same spot and everything where the exposed wire is.
i de-pined it too put some heat shrink tubing on it.
looks like smaller wire is on top and the bigger white wire is on the bottom.
then i have it wired wrong, hope I didn't fry the alt.
Old 04-13-2013, 06:07 PM
Re: Alternator Plug
When you buy a new alternator plug, it comes with two 4" wires already attached. They are both the same size (about the same diameter as the smaller wire) and the colors are blue and brown.
